One or more pixelated square artifacts in output TIF from Photo AI
Using a Macbook Proc 16" (2019)
Steps to reproduce issue:
  1. Use “Edit IN” from LrC to launch Photo AI for specific image
  2. Use Denoise option
  3. Export back to LrC as TIF
You can usually see the artifact while still in Photo Ai, BEFORE returning to LrC
This has occurred in about 20% of the images I’ve processed in the last 2 days. Artifact is a square grid or matrix pattern with objects that almost look like they came from my desktop except very small.
  1. The original image file.
  2. The processed image.
Dropbox File Request
