Nyx has a tool tip stating that it only runs at a 1x scale and does not use AI to upscale. Yet when you have two pass enhancement enabled, with Nyx as the first pass and something else at the second pass, the UI still says that an AI will not be used for upscaling, but the second pass is an AI that will be used for upscaling.
Thanks for reporting this. We’re going to work on improving the messaging for the Nyx model when used as part of a Second Enhancement processing task, and make sure that the model is always run at 1x scaling with the other Enhancement model handling all resizing.
This message displays at 3.5.1 no matter what the input/output resolution is set to.
My output has all settings on “original” and it still says it won’t use AI.
Guess it’s broken?
