This reminds me of the time when Theia was ignoring input parameters.
Here’s the setup:
NTSC DVD source. Square pixel. Nyx 2 manual at 1x to PNG. Gaia on those, to highlight results.
(I’m running all these passes in the CLI and Gaia happens because that’s how my script is setup.)
First off Here’s the result of the same setup but with Nyx 1, noise=0.10.
It looks pretty close to the source but cleaned up quite a bit:
Now to Nyx 2. I always reset every parameter to 0 except the one being tested.
All parameters at 0:
preblur=0.8:
preblur=-0.8:
noise=0.8:
details=0.8:
halo=0.8:
blur=0.8:
compression=0.8:
I’ll try combining the preblur=-0.80 with some compression and noise settings, but I’m not overly hopeful.
Anyway, this may not be an issue on larger resolutions. For DVDs, as of right now, it is very useless.
At least I can still use Nyx 1. No big deal if this is not what Nyx is made for. It just looks like it’s so close to being useful. If it would just not over-sharpen.
