:latest Photo AI sees my GPU AMD Radeon 6600, but processing is using GPU.
Preferences are set to use the GPU
restarted Photo AI … no joy
Rebooted computer, still no joy
Also, if you can open Topaz Photo AI, go to Help > Open Log Folder, and please send me all the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something.
I do not have access to the Google Drive log files. Would you mind sharing these examples to my Dropbox using the link above in this thread to help investigate this problem?
