Not redering multiple files, and others
Hello,
I have just updated to Video AI 6 and am unable to render multiple files. my typical workflow is to open multiple projects tweaking each and clicking export for each project. The resulting files are incomplete but play well until that point. Less of the files render the more I “check in” go to the Export Que for each (which also seems to switch which files are rendering).
I have also noticed that the Export Que may list multiple copys of a file but even with “All sources” clicked it only displays one video.
I am unable to find the setting to repeat or Loop a previewed section of a video, has this been removed?
After waking from sleep or just a screen power down (I have just set my system to not sleep) the window is often larger than my screen and may or may not contain anything in the large grey window. I can minimize to the task bar and bring it back but it will still be the same grey, if I let the computer shut down the monitors again it might resolve or might take a few cycles of this to resolve (it is still rendering).
logsForSupport.zip (1.5 MB)
Device name Tower
Processor Intel(R) Core™ i5-10600K CPU @ 4.10GHz 4.10 GHz
Installed RAM 80.0 GB (79.8 GB usable)
Device ID 82E3F9E2-FAA2-4FB1-AA50-5FB5B7CCAA71
Product ID 00330-80000-00000-AA510
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 11 Pro
Version 24H2
Installed on ‎3/‎25/‎2025
OS build 26100.3476
Experience Windows Feature Experience Pack 1000.26100.54.0
NVIDIA
GeForce RTX 4060 Ti
Studio Driver 572.83
The looping feature is set when using In/Out markers and rendering from In to Out for a preview.
We do not recommend exporting multiple files at the same time within different projects as this can cause conflicts in the export queue.
The display resizing and producing grey windows is new and I will send a note to the team about this to see if they can sort out what is going on there.
Can you please help me understand when I am opening multiple project vs having multiple renders in the same project. It is important to my productivity that I can set up several different items to render at once so that I can focus on other work while clips are rendering. While I prefer to render more than one clip at a time in parallel processing so that short clips render faster and long clips can keep going for days.
You would want to change the Max Processes to 2 then so that the app can try and run two exports at the same time. However, this does run the risk of an error occurring as now the GPU will be trying to run two exports and this can overwhelm your system. Especially if you are trying to do other tasks on the system at the same time.
To run multiple exports you will need them in the same Project and send them to the export queue.
Here is a quick video that might help show this workflow.
