Hi!
When I process my interlaced video the picture and sound are no longer in sync.
System:
Topaz Video Ai 5.2.1
MacBook Pro M3 Max, 64GB, Sonoma 14.5
What´s the problem?
The original frames should still occur at the original timestamps, while the 25 interpolated frames are placed between and alongside them, so A/V sync should not be effected.
This is a reasonably new issue that has cropped up over the last few months.
Edit : output is variable framerate (at least from TVAI output) rather than constant. Metadata framerate is also different between the stream and container (MKV) which doesn’t help.
