I have uninstalled Handbrake and Video AI, then reinstalled Video AI v3.1.5.0.b, which should have removed all instances of ffmpeg, so I understand.
Still getting command line interface error:
BEGIN
No such filter: ‘tvai_up’
Error initializing complex filters.
Invalid argument
END
Complete command, copied from GUI > Process > Show Export Command:
BEGIN
Roberts-MacBook:MacOS eidschun$ ffmpeg “-hide_banner” “-nostdin” “-y” “-nostats” “-framerate” “29.97” “-start_number” “61” “-i” “/System/Volumes/Data/Documents/The Wine Cellar - consultation scene - TIFF images/the_wine_cellar_trailer_image_sequence_no_titles_%04d.tif” “-sws_flags” “spline+accurate_rnd+full_chroma_int” “-color_trc” “2” “-colorspace” “2” “-color_primaries” “2” “-filter_complex” “tvai_up=model=prob-3:scale=0:w=3840:h=2160:preblur=0:noise=0:details=0:halo=0:blur=0:compression=0:estimate=20:device=0:vram=1:instances=1,scale=w=3840:h=2160:flags=lanczos:threads=0:force_original_aspect_ratio=decrease,pad=3840:2160:-1:-1:color=black” “-c:v” “prores_videotoolbox” “-profile:v” “lt” “-pix_fmt” “p210le” “-allow_sw” “1” “-map_metadata” “0” “-movflags” "frag_keyframe+empty_moov+delay_moov+use_metadata_tags+write_colr " “-map_metadata:s:v” “0:s:v” “-an” “-metadata” “videoai=Enhanced using prob-3 auto with recover details at 0, dehalo at 0, reduce noise at 0, sharpen at 0, revert compression at 0, and anti-alias/deblur at 0. Changed resolution to 3840x2160” “/System/Volumes/Data/Documents/The Wine Cellar - consultation scene - TIFF images_prob3_temp.mov”
Input #0, image2, from ‘/System/Volumes/Data/Documents/The Wine Cellar - consultation scene - TIFF images/the_wine_cellar_trailer_image_sequence_no_titles_%04d.tif’:
Duration: 00:00:00.33, start: 0.000000, bitrate: N/A
Stream #0:0: Video: tiff, rgb24, 720x480 [SAR 1:1 DAR 3:2], 29.97 fps, 29.97 tbr, 29.97 tbn, 29.97 tbc
[AVFilterGraph @ 0x7f8ead604a80] No such filter: ‘tvai_up’
Invalid argument
END
Here’s a screen shot:
I would be grateful for any solution. Thank you. - Robert
