If I load any kind of .AVI files into Topaz Video AI the preview won’t render. The file itself is displayed correctly by the player interface, timeline skipping is fine too. But if I click upon the prview button it will state that it is processing (0% etc.), the green bar seems to appear very briefly only to then vanish instantly. The picture in the two tabs will stay the same, the enhancement tab is exactly like the original tab, no preview possible. I’ve tried this with different codecs contained within the .AVI container and different models. The same file works absolutely fine after simply being remuxed into an .MKV container. The .AVI file is also correctly processed through the export option.
We have bene unable to replicate this issue in our tests. Can you share the file you are using for the team to look at and use?
