New Issue - IVTC goes from 25fps PAL to 23.976fps, when it should be 24fps for PAL
Not sure if it’s truly a bug, but definitely an overlooked issue. When loading a 25fps PAL stream, IVTC goes from 25fps PAL to 23.976fps, when it should be 24fps for PAL. Perhaps there should be an option to choose which one?
OS Name Microsoft Windows 11 Pro for Workstations
Processor AMD Ryzen 9 3900X 12-Core Processor, 3801 Mhz, 12 Core(s), 24 Logical Processor(s)
Installed Physical Memory (RAM) 64.0 GB
GPU NVIDIA GeForce RTX 3060, 12.0 GB vRAM
Are you able to share your logs of this happening? The team is going to try and replicate this on their end if they can but having your logs will help as well for comparison.
