Windows 11 RTX 3060 Ryzen 5700x
Processing in GUI works and inferences works
But command prompt doesn’t start (Process > Open Command Prompt) gives a flash of a cmd screen but closes instantly, manually going to D:/programmes/tvai/ffmpeg.exe and using the command
D:/programmes/tvai/ffmpeg.exe "-hide_banner" "-i" "R:/pp.mkv" "-sws_flags" "spline+accurate_rnd+full_chroma_int" "-color_trc" "2" "-colorspace" "2" "-color_primaries" "2" "-filter_complex" "tvai_up=model=prob-3:scale=0:w=1800:h=3200:preblur=0:noise=0:details=0:halo=0:blur=0:compression=0:estimate=20:blend=0.2:device=0:vram=1:instances=1,scale=w=1800:h=3200:flags=lanczos:threads=0" "-c:v" "h264_nvenc" "-profile:v" "high" "-pix_fmt" "yuv420p" "-preset" "p7" "-tune" "hq" "-rc" "constqp" "-qp" "18" "-rc-lookahead" "20" "-spatial_aq" "1" "-aq-strength" "15" "-b:v" "0" "-an" "-map_metadata" "0" "-map_metadata:s:v" "0:s:v" "-movflags" "frag_keyframe+empty_moov+delay_moov+use_metadata_tags+write_colr" "R:/pp_prob3_temp.mp4"
Gives
[Parsed_tvai_up_0 @ 000002731FBDEF00] Model not found: prob-3
