Memory leak when batch processing images: not quite resolved in v3.0.4/Mac
Searched for this issue, found “batch-processing-memory-leak-macos-application-runs-out-of-memory/64875”, which is marked as resolved and no longer allows for replies. I’m still seeing a memory leak, albeit in a slight different context.
Photo AI version 3.0.4, M1 Mac Mini, MacOS Sonoma 14.4.1
I’m denoising a set of raw images from a Nikon D850. Input files are in NEF format, size per file is in the 60MB-64MB range. I’m saving them as JPEG with quality 95. Output file sizes are in the 7MB-8MB range. My process:
  1. Select 10 images in the Finder and drag/drop them onto Topaz Photo AI
  2. Click “Select all”
  3. Select menu item File → Save
  4. Select Format:JPEG, Quallity:95 (already preselected after doing this the first time)
  5. Click the “Save” button.
  6. Wait for all images to be processed
  7. Click “Close Window” (closing the window takes 5.5 seconds after clicking the button)
  8. Select menu item File → Close all images and click “OK” in the dialog
  9. Check the memory usage of Topaz Photo AI in MacOS’s Activity Monitor
  10. Go to step 1 for the next batch of 10 images
I find that for each iteration, the memory usage of Topaz Photo AI as monitored in step 9 increases by about 3GB. Eventually, the system runs out of application memory and brings up the “Force quit” dialog to select an application to quit.
Topaz Labs Download Page
