I’m on a Mac Studio with 128GB of ram, and I get out of memory errors all the time. Please can you fix it, it really messes up a workflow if a percentage of the renders fail.
Can you please share your logs?
Same rig same experience for me as well.
@ian.ellis @rufus_blackwell This should be resolved in the next major release. We have a fix in Alpha that you can both test, if you are not already Beta testers, please let me know and I will DM you the installer links!
Thank you for the info! And I would love to test out the Alpha/Beta.
Is this release out yet because I just updated to the newest version and 64GB ram not even half filled and I’m still getting the out of memory errors.
and, yes, I did send logs etc when it first began happening but received no real reply or info.
It’s the same error every time so I can’t be bothered to keep reporting and sending logs.
This is still a massive issue for me. It’s making topaz unusable for big jobs
