I know this is still fairly common, but here is another example of errors in applying Denoise and Sharpening to some photos.
Steps to reproduce issue:
Load Sony .ARW file (50MP from ICLE-1)
Change the Denoise and/or Sharpening settings to what is shown in my screenshot.
Removing Noise: RAW Normal, Strength 1, Minor Deblur 15
Sharpening: Standard, Strength 47, Minor Denoise 1
Observe the magenta error in the preview window once it is done updating. Optionally export the photo to see the errors there as well.
Topaz Photo AI [v1.5.0] on Mac Studio M1 Ultra 128GB macOS Ventura 13.4.1 (c)
Lingyu
August 8, 2023, 8:56pm
The best work-around for now is to use the Remove Noise - Raw Strong model or convert the Raw to a TIFF using Photo > Edit in > Topaz Photo AI.
We are working on new Raw Remove Noise models which should prevent this. Those are coming in about 1 month.
Perfect, thank you for taking the time to provide me with a temporary solution and an estimate timeline on a possible fix. No software product is ever “perfect”, but this is how to be “perfectly” accountable to and supportive of your customers!
system
(system)
Closed
October 7, 2023, 9:24pm
4
