When I edit a Canon CR2 file using the File\Plug-in Extras\Process with Topaz Photo AI the returned image has a distinct magenta color cast.
Steps to reproduce issue:
- Open CR2 in LRc (current version)
- Select File\Plug-in Extras\Process with Topaz Photo AI
- Let autopilot do its thing - Raw Denoise
- Save to Adobe LrC
Topaz Photo AI v2.4.2 on Windows 11 Home
2024-04-15-11-24-42.tzlog (64.4 KB)
DxDiag.txt (147.0 KB)
I would like to see if updating your GPU driver will resolve the problem.
Please use the following link to update your driver: NVIDIA | Driver Update
Installed the new driver. No change in the behavior. One thing I did fail to mention is that if I process the image as Right click\Edit in\Topaz Photo AI, there is no apparent shift in color. Only when invoked as a plug-in.
David
- The original image file.
- The processed image.
- A screenshot or description of the settings panel so I can see what adjustments were turned on.
Dropbox File Request
Files sent. I’ve noticed that brightness is also affected. I can return the Topaz treated file to similar appearance to the original by changing the color temp from 5850 to around 6275, reducing tint by minus 14 (more green), and reducing exposure by -0.25 stop.
Hello, any update on this?
David
I was not able to replicate this color shift on my machine but I will note that I am using v3.0.1 and noticed you are on v2.4.2
Try using the link below to update:
Topaz Labs | Support Page
