latest update not working on Mac, can I go back to a earlier program?
If you would like to revert to any previous Topaz Photo AI version, you can find a list of previous installers at the following link:
Topaz Labs | Community Forums | Topaz Photo AI | Releases
If you would like to try and troubleshoot this problem you are having please follow the instructions below to perform a clean install:
Hi, I tried everything you said and it worked once than it would go back to freezing on the next photo I tried to work on
I’d like to get some more information to help troubleshoot the problem you are having.
Could you send us your computer’s full system profile?
Also if you can, please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something.
