The issue I’m experiencing when using the ‘Jittery Motion’ feature is that it creates a cross fade on a hard cut. The previous frames are bleeding from one scene/sequence into another when it doesn’t in the original. It would be great to have this issue get fixed as this feature in very good.
The Jittery Motion tool works by applying Chronos Fast to help fix parallax distortion and titling motion, which can result in some frame blending depending on how many passes it runs. Increasing the amount of passes will amplify the effect.
