Thanks for reaching out. Please send the following information so I can try to reproduce this.
The original image file.
The processed image.
The XMP file that goes with the NEF file.
You can securely submit your image(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something. Dropbox File Request
@Lingyu uploaded the 3 files ( name = Great_Meadows_04272023_016)
One more piece of information - If I make no changes to the RAW except cropping the only issue I see is that the cropping doesn’t appear in the DNG file.
@golder-50350 Thanks for uploading those. Lingyu will be out until Wednesday but he’ll get back to you as quickly as possible. We appreciate your patience!
The cropping not getting transferred to the output image is expected behavior. We do not support cropping yet.
I was able to reproduce the saturation and sharpening settings changing in the output image. I made a task for my team to look into this.
I will check with the previous version to see if this happened in the past or if this has always been an issue. If it’s a new problem that was not in a previous version, then it’s likely we will fix it soon.
