I recently (March 15, 2024) downloaded into LR several images (77) that were from the 1960’s.
I adjusted about half of them in Topaz AI (as Tiff’s) and put them back in LR and into my backup’s (3 separate HD’s).
After the last update they missing out of LR.
The Images are still in my 3 HD B/U drives.
I have a Mac Studio.
At 81 years old I tend to blame myself for these types of occurrences, LOL.
Are you aware of this being an issue?
Is there a way to retrieve these images from Topaz or is there a way going forward to have Topaz store the adjusted images in some type of folder?
Can you confirm with me which Lightroom plugin you are using:
- The RAW plugin | File > Plug-in Extras > Process with Topaz Photo
- The External Editor plugin | Photo > Edit in > Topaz Photo AI
Just to note the RAW plugin your output file is saved in the same folder as the original file. Output files are not automatically added to collections.
I use :LR > Photo > Edit In > Topaz Photo AI
I have no luck with the Edit > Plug in Extras as it removes all the adjustments I have made in LR to determine what additional changes I need in Topaz.
If I am doing it wrong, is there a way to make the Topaz adj keeping the LR adjustments ?
Thanks for the quick response,
Greg
I received an E-mail yesterday morning, it only repeated my original post, there was no response.
Is that normal?
Thanks,
Greg
