The bug / behavior you have encountered
I was enhancing a video - can’t remember the exact enhancement configuration - but it was raising the frame rate from 29.97fps to 60 fps and enhancing the video with the Iris model (same resolution). The process ran for over a day and simply failed with “Error X” at the very end. -
Your system profile
MacBook Pro 13-inch 2021
Chip: Apple M1 Pro
Memory: 16GB
macOS: 15.1 (24B83) -
Your log files (Help > Logging > Get Logs for Support)
logsForSupport.zip (917.4 KB)
- Any screenshots as necessary
Also, is there a temp file somewhere I can retrieve to salvage some of the upscaled video? Thanks
