The bug / behavior you have encountered — “Installation Failed” error message (see screenshot)
Your system profile — MacBook Pro, 14-inch, 2023, Apple M2 Pro, 16MB RAM
Your log files (Help > Logging > Get Logs for Support)
Any screenshots as necessary
AND-E
December 25, 2024, 7:22pm
Hi.
Check if you use any VPN, Firewall, Proxy, or antivirus. Disable them one by one and try again.
You could also try a fresh Install here’s the link for Video AI version 6
https://topazlabs.com/d/tvai/latest/mac/full
Hope this helps
This can be caused by the anti-virus blocking the models and data from downloading completely. As And-E mentioned try turning them off and downloading a clean installer to try again.
If that does not work, please email the support team directly so we can get more details.
help@topazlabs.com
system
(system)
Closed
February 24, 2025, 1:43pm
4
