I use Image > Edit with > Process with Topaz Photo AI
Edit with a DNG file
Than I works with Topaz and Save to Capture One
The white balance and the color tone are then shifted to completely unnatural colors. Usually an extreme green cast
I use Topaz Photo AI 2.2.0 and Capture one 23.3.3 on a Mac
Same here – I have filed a bug report but it just disappeared…
There are some more issues now: the worst thing is a checker pattern that happens on RAW files. There was a case on it but it was closed as support says it is not a problem with new RAW models now - which is just not true ![]()
Oh, sorry, I’ve also seen your post now
I have new insights into the problem.
It doesn’t affect all cameras. Topaz has no problems with my A7c but my APSC camera A6700 has this extreme color cast.
It also affects not only Capture One but also Lightroom. The same effect in every program
