Why are the colors completely screwed up when I export directly into Photoshop? This seems to happen with all of the non-generative models.
yes sure ![]()
I have deleted CoremMLCache but this not helps…
Here is my Log:
2025-03-21-08-33-0.tzlog.zip (10.6 KB)
In fact you are not “recovering”, you are asking the AI to create a high res image based on the low quality image you gave. The AI “invents” (generates / creates) an image that is no too objectionable, but nothing is actually “recovered” from your low quality image. That’s how Topaz Gigapixel AI works. This is generative AI.
Yes, I noticed this yesterday with one of my photos. Exactly the same problem.
Well, it’s based on the overall image to make something better.
Redefine is now working on M1 Max - Thank you!
Incidentally, I encountered this error:
from the latest log file:
[2025-03-21 08:55:59.152, 11.00 μs] [179dfb000] Info | [AIE] Image Model inference failed: unable to run model with index 0
[2025-03-21 08:55:59.152, 36.00 μs] [16fe8b000] Info | [AIE] Error handling block: unable to run model with index 0
[2025-03-21 08:55:59.155, 3.29 ms] [16fe8b000] Error | Exception: "Exception: AIProcessor failed: unable to run model with index 0"
[2025-03-21 08:55:59.156, 15.69 m] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 08:55:59.157, 547.00 μs] [1f52e0840] Info | [EXPORT] All images exported | (qrc:/qt/qml/gigapixel/service/ImageExporter.qml:128, checkIfDone)
[2025-03-21 08:55:59.158, 1.41 ms] [1f52e0840] Info | [EXPORT] Done exporting | (qrc:/qt/qml/gigapixel/service/ImageExporter.qml:198, completeExport)
[2025-03-21 09:21:57.389, 25.97 m] [1f52e0840] Info | Opening directory: "/Users/michaelezra/Library/Application Support/Topaz Labs LLC/Topaz Gigapixel AI/Logs"
Before installing the latest GAI, I removed the previous version, deleted the ‘/Users/michaelezra/Library/Application Support/coreMLCache’ folder
I deleted coreMLCache again, still same error.
Changed input image, changed redefine settings - still same error.
Something broke - by itself. Please advise what should I do?
Uninstalled GAI
Reinstalled GAI
same error again.
Log:
2025-03-21 10:24:58.040, 14.68 ms] [1f52e0840] Info | Auth state changed: Owned | (qrc:/qt/qml/gigapixel/main.qml:1599, onStateChanged)
[2025-03-21 10:24:58.048, 8.70 ms] [1f52e0840] Info | [AIE] === System Information ===
[2025-03-21 10:24:58.049, 49.00 μs] [1f52e0840] Info | [AIE] OS Mac Version 15.030200
[2025-03-21 10:24:58.049, 11.00 μs] [1f52e0840] Info | [AIE] CPU Apple M1 Max Threads 10 AVX 0 AVX2 0 VNNI 0
[2025-03-21 10:24:58.049, 9.00 μs] [1f52e0840] Info | [AIE] Is Apple Processor 1 Hexagon 0
[2025-03-21 10:24:58.049, 9.00 μs] [1f52e0840] Info | [AIE] RAM 64.000000 GB Total / 0.084778 GB Used
[2025-03-21 10:24:58.049, 8.00 μs] [1f52e0840] Info | [AIE] Machine Id: XXX-edited-XXX
[2025-03-21 10:24:58.049, 8.00 μs] [1f52e0840] Info | [AIE] Device count: 1
[2025-03-21 10:24:58.049, 21.00 μs] [1f52e0840] Info | [AIE] - Index 0 Name Apple M1 Max Cores 32
[2025-03-21 10:24:58.049, 10.00 μs] [1f52e0840] Info | [AIE] VRAM 48.000000 GB Total / 0.000000 GB Used DataType 2
[2025-03-21 10:24:58.049, 8.00 μs] [1f52e0840] Info | [AIE] Serial XXX-edited-XXX x Legacy 0 0 CudaId 0 Capability 0
[2025-03-21 10:24:58.049, 7.00 μs] [1f52e0840] Info | [AIE] ==========================
[2025-03-21 10:24:58.049, 19.00 μs] [1f52e0840] Info | Started listening for theme changes using MacOSThemeListener.
[2025-03-21 10:24:58.050, 1.86 ms] [1f52e0840] Info | QML engine loaded
[2025-03-21 10:24:58.055, 106.88 ms] [16c5ab000] Info | libpng warning: iCCP: known incorrect sRGB profile
[2025-03-21 10:24:58.058, 2.98 ms] [16c5ab000] Info | libpng warning: iCCP: known incorrect sRGB profile
[2025-03-21 10:24:58.090, 39.30 ms] [1f52e0840] Warn | Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
[2025-03-21 10:24:58.090, 75.00 μs] [1f52e0840] Warn | Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
[2025-03-21 10:24:58.090, 35.00 μs] [1f52e0840] Warn | Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
[2025-03-21 10:24:58.327, 334.25 ms] [16c867000] Info | Created exiftool
[2025-03-21 10:24:58.339, 12.73 ms] [16c867000] Info | Exiftool metadata count: 22 File: "/Users/michaelezra/ai/outputs-2022/001045.fbeb2292.4074782983.png"
[2025-03-21 10:24:58.339, 40.00 μs] [16c867000] Info | Exiftool metadata size: 3072
[2025-03-21 10:24:58.345, 254.75 ms] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/ai/outputs-2022/001037.83fee4eb.4074782983.png"
[2025-03-21 10:24:58.347, 7.87 ms] [16c867000] Info | Exiftool metadata count: 22 File: "/Users/michaelezra/ai/outputs-2022/001037.83fee4eb.4074782983.png"
[2025-03-21 10:24:58.347, 27.00 μs] [16c867000] Info | Exiftool metadata size: 3072
[2025-03-21 10:24:58.353, 7.85 ms] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/ai/outputs-2022/001031.655406f1.4074782983.png"
[2025-03-21 10:24:58.355, 7.99 ms] [16c867000] Info | Exiftool metadata count: 22 File: "/Users/michaelezra/ai/outputs-2022/001031.655406f1.4074782983.png"
[2025-03-21 10:24:58.355, 27.00 μs] [16c867000] Info | Exiftool metadata size: 3072
[2025-03-21 10:24:58.361, 8.28 ms] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1508.jpg"
[2025-03-21 10:24:58.390, 35.07 ms] [16c867000] Info | Exiftool metadata count: 297 File: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1508.jpg"
[2025-03-21 10:24:58.390, 58.00 μs] [16c867000] Info | Exiftool metadata size: 40620
[2025-03-21 10:24:58.394, 33.33 ms] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1457-Pano_V1.jpg"
[2025-03-21 10:24:58.410, 19.91 ms] [16c867000] Info | Exiftool metadata count: 291 File: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1457-Pano_V1.jpg"
[2025-03-21 10:24:58.410, 52.00 μs] [16c867000] Info | Exiftool metadata size: 27834
[2025-03-21 10:24:58.411, 17.07 ms] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1831.jpg"
[2025-03-21 10:24:58.428, 17.63 ms] [16c867000] Info | Exiftool metadata count: 348 File: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1831.jpg"
[2025-03-21 10:24:58.428, 52.00 μs] [16c867000] Info | Exiftool metadata size: 38938
[2025-03-21 10:24:58.428, 17.16 ms] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1549.jpg"
[2025-03-21 10:24:58.444, 15.81 ms] [16c867000] Info | Exiftool metadata count: 349 File: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1549.jpg"
[2025-03-21 10:24:58.444, 55.00 μs] [16c867000] Info | Exiftool metadata size: 43074
[2025-03-21 10:24:58.444, 16.04 ms] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1208.jpg"
[2025-03-21 10:24:58.458, 13.75 ms] [16c867000] Info | Exiftool metadata count: 294 File: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1208.jpg"
[2025-03-21 10:24:58.458, 48.00 μs] [16c867000] Info | Exiftool metadata size: 36694
[2025-03-21 10:24:58.461, 16.71 ms] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1228.jpg"
[2025-03-21 10:24:58.475, 17.21 ms] [16c867000] Info | Exiftool metadata count: 294 File: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1228.jpg"
[2025-03-21 10:24:58.475, 55.00 μs] [16c867000] Info | Exiftool metadata size: 39370
[2025-03-21 10:24:58.478, 16.45 ms] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1114-SharpenAI-Motion.jpg"
[2025-03-21 10:24:58.490, 14.80 ms] [16c867000] Info | Exiftool metadata count: 277 File: "/Users/michaelezra/Travel-Files/WLSR_20250128/WLSR_20250128_1114-SharpenAI-Motion.jpg"
[2025-03-21 10:24:58.490, 46.00 μs] [16c867000] Info | Exiftool metadata size: 19462
[2025-03-21 10:24:59.200, 722.79 ms] [1f52e0840] Info | JWT status: "active"
[2025-03-21 10:24:59.201, 548.00 μs] [1f52e0840] Info | Auth response | AUD: "388664" | ISS: "plutus" | IAT: 1742567098 | EXP: 1745159099 | UID: "18317" | TIER: Individual | STAT: "active"
[2025-03-21 10:24:59.201, 567.00 μs] [1f52e0840] Info | Avatar is out of date, trying to refresh
[2025-03-21 10:24:59.203, 1.76 ms] [1f52e0840] Info | [F] Getting features
[2025-03-21 10:24:59.255, 52.12 ms] [1f52e0840] Info | Found 0 new app versions
[2025-03-21 10:24:59.256, 235.00 μs] [1f52e0840] Info | Update check response: true false
[2025-03-21 10:24:59.335, 79.02 ms] [1f52e0840] Info | JWT status: "active"
[2025-03-21 10:24:59.335, 144.00 μs] [1f52e0840] Info | Auth response | AUD: "388664" | ISS: "plutus" | IAT: 1742567099 | EXP: 1745159099 | UID: "18317" | TIER: Individual | STAT: "active"
[2025-03-21 10:24:59.335, 600.00 μs] [1f52e0840] Info | [F] Finishing auth without checking features true false false true
[2025-03-21 10:24:59.337, 1.84 ms] [1f52e0840] Info | Auth state changed: Owned | (qrc:/qt/qml/gigapixel/main.qml:1599, onStateChanged)
[2025-03-21 10:24:59.431, 93.52 ms] [1f52e0840] Info | Found 0 new app versions
[2025-03-21 10:24:59.431, 157.00 μs] [1f52e0840] Info | Update check response: true false
[2025-03-21 10:24:59.457, 25.82 ms] [1f52e0840] Info | E-mail does not have a gravatar icon associated with it
[2025-03-21 10:24:59.685, 228.83 ms] [1f52e0840] Info | Session files log written.
[2025-03-21 10:24:59.686, 256.00 μs] [1f52e0840] Info | [EXIF] Thumbnail writer reading metadata for: "/Users/michaelezra/ai/outputs-2022/001045.fbeb2292.4074782983.png"
[2025-03-21 10:24:59.686, 40.00 μs] [1f52e0840] Info | Time to insert 1 files: "783.084 μs"
[2025-03-21 10:24:59.686, 1.20 s] [16c867000] Info | Returning cached metadata for "/Users/michaelezra/ai/outputs-2022/001045.fbeb2292.4074782983.png"
[2025-03-21 10:24:59.693, 7.10 ms] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:24:59.693, 57.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:24:59.693, 24.00 μs] [1f52e0840] Info | Loading file: "/Users/michaelezra/ai/outputs-2022/001045.fbeb2292.4074782983.png"
[2025-03-21 10:24:59.713, 19.78 ms] [1f52e0840] Info | Reading metadata
[2025-03-21 10:24:59.713, 51.00 μs] [1f52e0840] Info | [EXIF] Image reader loading metadata for: "/Users/michaelezra/ai/outputs-2022/001045.fbeb2292.4074782983.png"
[2025-03-21 10:24:59.713, 27.02 ms] [16c867000] Info | Returning cached metadata for "/Users/michaelezra/ai/outputs-2022/001045.fbeb2292.4074782983.png"
[2025-03-21 10:24:59.713, 127.00 μs] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:24:59.713, 383.00 μs] [1f52e0840] Info | Estimated ETA for the machine 0
[2025-03-21 10:24:59.724, 10.43 ms] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:24:59.724, 46.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:24:59.724, 92.00 μs] [1f52e0840] Info | Stopping TThumbnailWriterWorker thread
[2025-03-21 10:24:59.724, 53.00 μs] [1f52e0840] Info | TThumbnailWriterWorker thread stopped
[2025-03-21 10:24:59.725, 1.53 ms] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:24:59.726, 531.00 μs] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:24:59.726, 0.00 ns] [16c1d7000] Info | Loading image with metadata "/Users/michaelezra/ai/outputs-2022/001045.fbeb2292.4074782983.png"
[2025-03-21 10:24:59.727, 304.00 μs] [16c1d7000] Info | Can open in RAW pipeline: false
[2025-03-21 10:24:59.727, 184.00 μs] [16c1d7000] Info | Image spec: 576 768 3 Raw: false
[2025-03-21 10:24:59.742, 15.25 ms] [16c1d7000] Info | Time to check if image is monochrome: "3.08179 ms" QVariant(bool, false)
[2025-03-21 10:24:59.742, 71.00 μs] [16c1d7000] Info | No embedded ICC profile exists: "sRGB"
[2025-03-21 10:24:59.757, 15.17 ms] [16c1d7000] Info | Time to read image: "30.7253 ms"
[2025-03-21 10:24:59.757, 92.00 μs] [16c1d7000] Info | Total cost for caching image is 2654208 bytes
[2025-03-21 10:24:59.758, 31.70 ms] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:24:59.758, 18.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:24:59.758, 1.97 s] [16c14b000] Info | Calculating top level auto category
[2025-03-21 10:24:59.758, 38.00 μs] [16c14b000] Info | Detecting all input image quality parameters.
[2025-03-21 10:24:59.758, 352.00 μs] [1f52e0840] Info | Estimated ETA for the machine 600
[2025-03-21 10:24:59.758, 0.00 ns] [16c37b000] Info | Using bit depth from metadata: 8
[2025-03-21 10:24:59.758, 44.00 μs] [16c37b000] Info | Setting OIIO attribute "Compression" : QVariant(QString, "jpeg:91")
[2025-03-21 10:24:59.758, 16.00 μs] [16c37b000] Info | Setting OIIO attribute "estimation" : QVariant(bool, true)
[2025-03-21 10:24:59.758, 12.00 μs] [16c37b000] Info | Setting OIIO attribute "topaz:ColorSpace" : QVariant(QString, "preserve")
[2025-03-21 10:24:59.758, 15.00 μs] [16c37b000] Info | Set save options QMap(("Compression", QVariant(QString, "jpeg:91"))("estimation", QVariant(bool, true))("topaz:ColorSpace", QVariant(QString, "preserve")))
[2025-03-21 10:24:59.758, 13.00 μs] [16c37b000] Info | Opening OIIO ImageOutput "/private/var/folders/tr/j4pm6yc57g1d7b5w1xhjw5h80000gn/T/VglTgX.jpeg" Exists: true
[2025-03-21 10:24:59.759, 699.00 μs] [16c14b000] Info | [AIE] Model: gfp-s Device: -1
[2025-03-21 10:24:59.759, 18.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:24:59.759, 195.00 μs] [16c14b000] Info | [AIE] ---TBlockProc 1024x1024 C: 1/1 R: 1/1 X: 976 Y: 976 inSize: 1 1 Pad: 511 511
[2025-03-21 10:24:59.759, 12.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:24:59.759, 12.00 μs] [16c14b000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:24:59.759, 157.00 μs] [16c14b000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:24:59.759, 12.00 μs] [16c14b000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:24:59.759, 8.00 μs] [16c14b000] Info | [AIE] 1 instances for device -1
[2025-03-21 10:24:59.759, 20.00 μs] [16c14b000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:24:59.759, 24.00 μs] [16c14b000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gfp-s-v1-fp32-1024x1024-mlc.tz
[2025-03-21 10:24:59.759, 292.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache
[2025-03-21 10:24:59.759, 133.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gfp-s-v1-fp32-1024x1024-mlc.tz
[2025-03-21 10:24:59.760, 1.35 ms] [16c37b000] Info | Write Progress Callback: 0
[2025-03-21 10:24:59.760, 12.00 μs] [16c37b000] Info | Progress callback: "/private/var/folders/tr/j4pm6yc57g1d7b5w1xhjw5h80000gn/T/VglTgX.jpeg" 0
[2025-03-21 10:24:59.767, 8.77 ms] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:24:59.767, 674.00 μs] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:24:59.768, 391.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:24:59.768, 15.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:24:59.768, 306.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:24:59.768, 12.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:24:59.838, 78.48 ms] [16c37b000] Info | Write Progress Callback: 0
[2025-03-21 10:24:59.838, 39.00 μs] [16c37b000] Info | Progress callback: "/private/var/folders/tr/j4pm6yc57g1d7b5w1xhjw5h80000gn/T/VglTgX.jpeg" 0
[2025-03-21 10:24:59.838, 11.00 μs] [16c37b000] Info | Write Progress Callback: 1
[2025-03-21 10:24:59.838, 8.00 μs] [16c37b000] Info | Progress callback: "/private/var/folders/tr/j4pm6yc57g1d7b5w1xhjw5h80000gn/T/VglTgX.jpeg" 1
[2025-03-21 10:24:59.838, 32.00 μs] [16c37b000] Info | Image saved to: "/private/var/folders/tr/j4pm6yc57g1d7b5w1xhjw5h80000gn/T/VglTgX.jpeg"
[2025-03-21 10:24:59.840, 72.11 ms] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:00.357, 516.79 ms] [1f52e0840] Info | Estimate: QTime("00:00:13.000")
[2025-03-21 10:25:01.362, 1.60 s] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gfp-s-v1-fp32-1024x1024-mlc.tz/model/
[2025-03-21 10:25:01.363, 243.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gfp-s-v1-fp32-1024x1024-mlc.tz/neural_network_optionals/
[2025-03-21 10:25:01.363, 212.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gfp-s-v1-fp32-1024x1024-mlc.tz/analytics/
[2025-03-21 10:25:01.363, 347.00 μs] [16c14b000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:25:03.419, 2.06 s] [16c14b000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gfp-s-v1-fp32-1024x1024-mlc.tz is 3660
[2025-03-21 10:25:03.420, 356.00 μs] [16c14b000] Info | [AIE] faceParserSetup: 3662 ms
[2025-03-21 10:25:03.420, 21.00 μs] [16c14b000] Info | [AIE] Parsing faces from 576x768 image
[2025-03-21 10:25:03.422, 2.55 ms] [16c14b000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:25:03.487, 64.93 ms] [16c14b000] Info | [AIE] parseTime: 65 ms
[2025-03-21 10:25:03.487, 113.00 μs] [16c14b000] Info | [AIE] ImageFaceParser nms input: 41
[2025-03-21 10:25:03.487, 12.00 μs] [16c14b000] Info | [AIE] ImageFaceParser nms output: 1
[2025-03-21 10:25:03.498, 11.30 ms] [16c14b000] Info | [AIE] Detect faces. Will perform face refinement 1
[2025-03-21 10:25:03.498, 50.00 μs] [16c14b000] Info | [AIE] [ImageFaceParseFilter PROFILE] begin model loading
[2025-03-21 10:25:03.499, 283.00 μs] [16c14b000] Info | [AIE] Face Filter Device: -1
[2025-03-21 10:25:03.499, 15.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:03.499, 12.00 μs] [16c14b000] Info | [AIE] overlapping >2 blocks
[2025-03-21 10:25:03.499, 9.00 μs] [16c14b000] Info | [AIE] ---TBlockProc 48x48 C: 1/1 R: 1/1 X: 1 Y: 1 inSize: 48 48 Pad: 0 0
[2025-03-21 10:25:03.499, 8.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:03.499, 7.00 μs] [16c14b000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:25:03.499, 14.00 μs] [16c14b000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:25:03.499, 7.00 μs] [16c14b000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:25:03.499, 7.00 μs] [16c14b000] Info | [AIE] 1 instances for device -1
[2025-03-21 10:25:03.499, 48.00 μs] [16c14b000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:25:03.499, 9.00 μs] [16c14b000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gfpf-v1-fp16-48x48-mlc.tz
[2025-03-21 10:25:03.499, 238.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gfpf-v1-fp16-48x48-mlc.tz
[2025-03-21 10:25:03.511, 11.75 ms] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gfpf-v1-fp16-48x48-mlc.tz/model/
[2025-03-21 10:25:03.511, 131.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gfpf-v1-fp16-48x48-mlc.tz/neural_network_optionals/
[2025-03-21 10:25:03.511, 170.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gfpf-v1-fp16-48x48-mlc.tz/analytics/
[2025-03-21 10:25:03.511, 111.00 μs] [16c14b000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:25:03.630, 118.61 ms] [16c14b000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gfpf-v1-fp16-48x48-mlc.tz is 131
[2025-03-21 10:25:03.630, 301.00 μs] [16c14b000] Info | [AIE] [ImageFaceParseFilter PROFILE] finish model loading: 131 ms
[2025-03-21 10:25:03.630, 69.00 μs] [16c14b000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:25:03.632, 2.04 ms] [16c14b000] Info | Image analyzed
[2025-03-21 10:25:03.632, 50.00 μs] [16c14b000] Info | Calculating Upscale slider values and model selection
[2025-03-21 10:25:03.632, 15.00 μs] [16c14b000] Info | Calculating auto settings with auto model: "ggn_ap"
[2025-03-21 10:25:03.633, 3.28 s] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.633, 235.00 μs] [16c14b000] Info | [AIE] Model: ggn_ap Device: -1
[2025-03-21 10:25:03.633, 18.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:03.633, 14.00 μs] [16c14b000] Info | [AIE] ---TBlockProc 128x128 C: 9/9 R: 11/11 X: 80 Y: 80 inSize: 576 768 Pad: 96 80
[2025-03-21 10:25:03.633, 11.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:03.633, 8.00 μs] [16c14b000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:25:03.633, 13.00 μs] [16c14b000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:25:03.633, 8.00 μs] [16c14b000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:25:03.633, 7.00 μs] [16c14b000] Info | [AIE] 1 instances for device -1
[2025-03-21 10:25:03.633, 20.00 μs] [16c14b000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:25:03.633, 9.00 μs] [16c14b000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn_ap-v2-fp16-128x128-mlc.tz
[2025-03-21 10:25:03.633, 279.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/ggn_ap-v2-fp16-128x128-mlc.tz
[2025-03-21 10:25:03.633, 904.00 μs] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.634, 403.00 μs] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.659, 26.24 ms] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/ggn_ap-v2-fp16-128x128-mlc.tz/model/
[2025-03-21 10:25:03.659, 191.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/ggn_ap-v2-fp16-128x128-mlc.tz/neural_network_optionals/
[2025-03-21 10:25:03.660, 185.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/ggn_ap-v2-fp16-128x128-mlc.tz/analytics/
[2025-03-21 10:25:03.660, 118.00 μs] [16c14b000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:25:03.728, 68.42 ms] [16c14b000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn_ap-v2-fp16-128x128-mlc.tz is 95
[2025-03-21 10:25:03.730, 1.39 ms] [16c14b000] Info | [AIE] gamma: 0.750000
[2025-03-21 10:25:03.730, 18.00 μs] [16c14b000] Info | [AIE] maxBlocks: 5.000000
[2025-03-21 10:25:03.730, 121.00 μs] [16c14b000] Info | [AIE] Updated model params
[2025-03-21 10:25:03.735, 5.28 ms] [16c14b000] Info | [AIE] Auto params keys are param1 param2 param3
[2025-03-21 10:25:03.736, 1.26 ms] [16c14b000] Info | Calculating auto settings with auto model: "gde_ap"
[2025-03-21 10:25:03.737, 285.00 μs] [16c14b000] Info | [AIE] Model: gde_ap Device: -1
[2025-03-21 10:25:03.737, 18.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:03.737, 12.00 μs] [16c14b000] Info | [AIE] overlapping >2 blocks
[2025-03-21 10:25:03.737, 9.00 μs] [16c14b000] Info | [AIE] ---TBlockProc 64x64 C: 37/37 R: 49/49 X: 16 Y: 16 inSize: 576 768 Pad: 32 32
[2025-03-21 10:25:03.737, 10.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:03.737, 7.00 μs] [16c14b000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:25:03.737, 16.00 μs] [16c14b000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:25:03.737, 7.00 μs] [16c14b000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:25:03.737, 6.00 μs] [16c14b000] Info | [AIE] 1 instances for device -1
[2025-03-21 10:25:03.737, 22.00 μs] [16c14b000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:25:03.737, 8.00 μs] [16c14b000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gde_ap-v1-fp16-64x64-mlc.tz
[2025-03-21 10:25:03.737, 219.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gde_ap-v1-fp16-64x64-mlc.tz
[2025-03-21 10:25:03.755, 18.31 ms] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gde_ap-v1-fp16-64x64-mlc.tz/model/
[2025-03-21 10:25:03.755, 127.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gde_ap-v1-fp16-64x64-mlc.tz/neural_network_optionals/
[2025-03-21 10:25:03.755, 175.00 μs] [16c14b000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gde_ap-v1-fp16-64x64-mlc.tz/analytics/
[2025-03-21 10:25:03.756, 107.00 μs] [16c14b000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:25:03.834, 78.40 ms] [16c14b000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gde_ap-v1-fp16-64x64-mlc.tz is 97
[2025-03-21 10:25:03.836, 1.92 ms] [16c14b000] Info | [AIE] gamma: 1.000000
[2025-03-21 10:25:03.836, 24.00 μs] [16c14b000] Info | [AIE] maxBlocks: 5.000000
[2025-03-21 10:25:03.837, 1.09 ms] [16c14b000] Info | [AIE] Updated model params
[2025-03-21 10:25:03.841, 4.04 ms] [16c14b000] Info | [AIE] Auto params keys are param1 param2
[2025-03-21 10:25:03.843, 1.90 ms] [16c14b000] Info | Calculating top level auto category
[2025-03-21 10:25:03.843, 52.00 μs] [16c14b000] Info | Detecting all input image quality parameters.
[2025-03-21 10:25:03.843, 21.00 μs] [16c14b000] Info | [AIE] Face landmarks from cache.
[2025-03-21 10:25:03.843, 10.00 μs] [16c14b000] Info | [AIE] Detect faces. Will perform face refinement 1
[2025-03-21 10:25:03.843, 8.00 μs] [16c14b000] Info | [AIE] [ImageFaceParseFilter PROFILE] begin model loading
[2025-03-21 10:25:03.843, 209.32 ms] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.843, 251.00 μs] [16c14b000] Info | [AIE] Face Filter Device: -1
[2025-03-21 10:25:03.843, 16.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:03.843, 12.00 μs] [16c14b000] Info | [AIE] overlapping >2 blocks
[2025-03-21 10:25:03.843, 9.00 μs] [16c14b000] Info | [AIE] ---TBlockProc 48x48 C: 1/1 R: 1/1 X: 1 Y: 1 inSize: 48 48 Pad: 0 0
[2025-03-21 10:25:03.843, 32.00 μs] [16c14b000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:03.843, 8.00 μs] [16c14b000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:25:03.843, 14.00 μs] [16c14b000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:25:03.843, 8.00 μs] [16c14b000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:25:03.843, 6.00 μs] [16c14b000] Info | [AIE] 1 instances for device -1
[2025-03-21 10:25:03.843, 30.00 μs] [16c14b000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:25:03.843, 10.00 μs] [16c14b000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gfpf-v1-fp16-48x48-mlc.tz
[2025-03-21 10:25:03.843, 70.00 μs] [16c14b000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:25:03.844, 1.04 ms] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.846, 1.30 ms] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.846, 675.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:25:03.846, 18.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:25:03.846, 17.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:25:03.846, 8.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:25:03.846, 14.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:25:03.846, 7.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:25:03.859, 15.46 ms] [16c14b000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gfpf-v1-fp16-48x48-mlc.tz is 16
[2025-03-21 10:25:03.859, 294.00 μs] [16c14b000] Info | [AIE] [ImageFaceParseFilter PROFILE] finish model loading: 16 ms
[2025-03-21 10:25:03.859, 63.00 μs] [16c14b000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:25:03.861, 1.94 ms] [16c14b000] Info | Image analyzed
[2025-03-21 10:25:03.861, 33.00 μs] [16c14b000] Info | Calculating Upscale slider values and model selection
[2025-03-21 10:25:03.861, 14.00 μs] [16c14b000] Info | Using cached auto settings "ggn_ap" "/Users/michaelezra/ai/outputs-2022/001045.fbeb2292.4074782983.png-applyLensCorrection=true-Mon Feb 6 18:36:06 2023"
[2025-03-21 10:25:03.861, 10.00 μs] [16c14b000] Info | Using cached auto settings "gde_ap" "/Users/michaelezra/ai/outputs-2022/001045.fbeb2292.4074782983.png-applyLensCorrection=true-Mon Feb 6 18:36:06 2023"
[2025-03-21 10:25:03.862, 15.20 ms] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.862, 878.00 μs] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.863, 443.00 μs] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.863, 457.00 μs] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.864, 448.00 μs] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:25:03.867, 3.08 ms] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:25:03.867, 31.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:25:03.867, 17.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:25:03.867, 7.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:25:03.867, 13.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:25:03.867, 12.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:25:03.867, 6.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:25:03.867, 11.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:25:06.490, 2.62 s] [1f52e0840] Info | Device pixel ratio changed: 1 => 2
[2025-03-21 10:25:06.491, 386.00 μs] [1f52e0840] Info | Device pixel ratio changed: 1 => 2
[2025-03-21 10:25:06.494, 2.98 ms] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
continued below:
[2025-03-21 10:25:06.496, 2.11 ms] [1f52e0840] Info | Proc requested for QRect(62,2 360x360) in view: 0
[2025-03-21 10:25:06.496, 27.00 μs] [1f52e0840] Info | Proc params:
Enhance: { model: RecoveryXL, creativity: 3, texture: 3, denoise: 0.1, sharpen: 0.5, prompt: }
Output: 576x768 => 1152x1536 (2x)
[2025-03-21 10:25:06.497, 624.00 μs] [1f52e0840] Info | Starting proc -2
[2025-03-21 10:25:06.497, 579.00 μs] [1f52e0840] Info | Begin proc: QRect(62,2 360x360) QRect(62,2 360x360) false
[2025-03-21 10:25:06.497, 96.00 μs] [1f52e0840] Info | Proc requested for QRect(62,2 360x360) in view: 0
[2025-03-21 10:25:06.497, 2.64 s] [16c14b000] Info | Proc image worker started: QRect(62,2 360x360) => QRect(62,2 360x360)
[2025-03-21 10:25:06.497, 19.00 μs] [1f52e0840] Info | Begin proc: QRect(62,2 360x360) QRect(62,2 360x360) false
[2025-03-21 10:25:06.498, 646.00 μs] [16c14b000] Info | Proc image worker started: QRect(62,2 360x360) => QRect(62,2 360x360)
[2025-03-21 10:25:06.517, 0.00 ns] [16c0bf000] Info | [AIE] No model info found for Enhance - RecoveryXL
[2025-03-21 10:25:06.517, 912.00 μs] [16c0bf000] Info | wantROI size: QRectF(62,2 360x360)
[2025-03-21 10:25:06.518, 705.00 μs] [16c0bf000] Info | Process round is for pre-img-optimization
[2025-03-21 10:25:06.518, 42.00 μs] [16c0bf000] Info | Image dimensions: 576 768
[2025-03-21 10:25:06.518, 13.00 μs] [16c0bf000] Info | Mat dimensions: 360 360
[2025-03-21 10:25:06.519, 405.00 μs] [16c0bf000] Info | [AIE] Output size 720x720 2.000000 2
[2025-03-21 10:25:06.519, 17.00 μs] [16c0bf000] Info | [AIE] Initializing with 124x4x720x720 RecoveryXL 576x768 2.000000 -2
[2025-03-21 10:25:06.519, 19.00 μs] [16c0bf000] Info | [AIE] desired size 360x360
[2025-03-21 10:25:06.566, 47.81 ms] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Begin embedding
[2025-03-21 10:25:06.567, 308.00 μs] [16c0bf000] Info | [AIE] Model: rxl_embed Device: -2
[2025-03-21 10:25:06.567, 16.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:25:06.567, 18.00 μs] [16c0bf000] Info | [AIE] ---TBlockProc 768x77 C: 2/2 R: 1/1 X: 720 Y: 29 inSize: 1 1 Pad: 743 38
[2025-03-21 10:25:06.567, 195.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:25:06.567, 11.00 μs] [16c0bf000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:25:06.567, 20.00 μs] [16c0bf000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:25:06.567, 8.00 μs] [16c0bf000] Info | [AIE] [ -2:1 ]
[2025-03-21 10:25:06.567, 7.00 μs] [16c0bf000] Info | [AIE] 1 instances for device -2
[2025-03-21 10:25:06.567, 31.00 μs] [16c0bf000] Info | [AIE] Target Device: -2 Count: 1
[2025-03-21 10:25:06.567, 13.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_embed-v1-fp16-77x768-rev1-mlc.tz
[2025-03-21 10:25:06.567, 258.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_embed-v1-fp16-77x768-rev1-mlc.tz
[2025-03-21 10:25:06.567, 92.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_embed-v1-fp16-77x768-rev1-mlc.tz/weights/
[2025-03-21 10:25:10.115, 3.55 s] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_embed-v1-fp16-77x768-rev1-mlc.tz/analytics/
[2025-03-21 10:25:10.115, 149.00 μs] [16c0bf000] Info | [AIE] Using CoreML CPU/GPU mode
[2025-03-21 10:25:10.418, 303.45 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_embed-v1-fp16-77x768-rev1-mlc.tz is 3851
[2025-03-21 10:25:10.418, 62.00 μs] [16c0bf000] Info | [AIE] embLoadTime: 3851 ms
[2025-03-21 10:25:10.495, 76.43 ms] [16c0bf000] Info | [AIE] procTime: 76 ms
[2025-03-21 10:25:10.495, 77.00 μs] [16c0bf000] Info | [AIE] embProcessTime: 77 ms
[2025-03-21 10:25:10.512, 16.98 ms] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Finish embedding
[2025-03-21 10:25:10.526, 14.39 ms] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Begin resize
[2025-03-21 10:25:10.527, 247.00 μs] [16c0bf000] Info | [AIE] Model: ggn Device: -2
[2025-03-21 10:25:10.527, 22.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:25:10.527, 14.00 μs] [16c0bf000] Info | [AIE] ---TBlockProc 128x128 C: 5/5 R: 5/5 X: 116 Y: 116 inSize: 384 384 Pad: 104 104
[2025-03-21 10:25:10.527, 338.00 μs] [16c0bf000] Info | [AIE] Model: ggn_ap Device: -1
[2025-03-21 10:25:10.527, 13.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:10.527, 8.00 μs] [16c0bf000] Info | [AIE] ---TBlockProc 128x128 C: 6/6 R: 6/6 X: 80 Y: 80 inSize: 384 384 Pad: 72 72
[2025-03-21 10:25:10.527, 24.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:25:10.527, 8.00 μs] [16c0bf000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:25:10.527, 13.00 μs] [16c0bf000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:25:10.527, 7.00 μs] [16c0bf000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:25:10.527, 6.00 μs] [16c0bf000] Info | [AIE] 1 instances for device -1
[2025-03-21 10:25:10.527, 25.00 μs] [16c0bf000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:25:10.527, 8.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn_ap-v2-fp16-128x128-mlc.tz
[2025-03-21 10:25:10.527, 74.00 μs] [16c0bf000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:25:10.537, 9.59 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn_ap-v2-fp16-128x128-mlc.tz is 10
[2025-03-21 10:25:10.537, 515.00 μs] [16c0bf000] Info | [AIE] gamma: 1.000000
[2025-03-21 10:25:10.537, 13.00 μs] [16c0bf000] Info | [AIE] maxBlocks: 5.000000
[2025-03-21 10:25:10.537, 29.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:25:10.542, 4.69 ms] [16c0bf000] Info | [AIE] Auto params keys are param1 param2 param3
[2025-03-21 10:25:10.542, 42.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:25:10.542, 10.00 μs] [16c0bf000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:25:10.542, 17.00 μs] [16c0bf000] Info | [AIE] Using extra instances on M1 Pro/Max
[2025-03-21 10:25:10.542, 11.00 μs] [16c0bf000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:25:10.542, 7.00 μs] [16c0bf000] Info | [AIE] [ -3:3 -2:3 ]
[2025-03-21 10:25:10.542, 9.00 μs] [16c0bf000] Info | [AIE] 6 instances for device -2
[2025-03-21 10:25:10.542, 22.00 μs] [16c0bf000] Info | [AIE] Target Device: -3 Count: 3
[2025-03-21 10:25:10.542, 9.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn-v3-fp16-128x128-2x-mlc.tz
[2025-03-21 10:25:10.542, 214.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/ggn-v3-fp16-128x128-2x-mlc.tz
[2025-03-21 10:25:12.117, 1.57 s] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/ggn-v3-fp16-128x128-2x-mlc.tz/model/
[2025-03-21 10:25:12.117, 216.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/ggn-v3-fp16-128x128-2x-mlc.tz/neural_network_optionals/
[2025-03-21 10:25:12.117, 188.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/ggn-v3-fp16-128x128-2x-mlc.tz/analytics/
[2025-03-21 10:25:12.118, 133.00 μs] [16c0bf000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:25:13.248, 1.13 s] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn-v3-fp16-128x128-2x-mlc.tz is 2706
[2025-03-21 10:25:13.248, 55.00 μs] [16c0bf000] Info | [AIE] Target Device: -2 Count: 3
[2025-03-21 10:25:13.248, 12.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn-v3-fp16-128x128-2x-mlc.tz
[2025-03-21 10:25:13.248, 46.00 μs] [16c0bf000] Info | [AIE] Using CoreML CPU/GPU mode
[2025-03-21 10:25:13.395, 147.19 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn-v3-fp16-128x128-2x-mlc.tz is 147
[2025-03-21 10:25:13.395, 78.00 μs] [16c0bf000] Info | [AIE] Target Device: -3 Count: 3
[2025-03-21 10:25:13.395, 13.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gclc-v1-fp16-128x128-2x-mlc.tz
[2025-03-21 10:25:13.395, 186.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gclc-v1-fp16-128x128-2x-mlc.tz
[2025-03-21 10:25:13.396, 515.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gclc-v1-fp16-128x128-2x-mlc.tz/model/
[2025-03-21 10:25:13.396, 105.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gclc-v1-fp16-128x128-2x-mlc.tz/neural_network_optionals/
[2025-03-21 10:25:13.396, 153.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/gclc-v1-fp16-128x128-2x-mlc.tz/analytics/
[2025-03-21 10:25:13.396, 113.00 μs] [16c0bf000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:25:15.084, 1.69 s] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gclc-v1-fp16-128x128-2x-mlc.tz is 1689
[2025-03-21 10:25:15.084, 56.00 μs] [16c0bf000] Info | [AIE] Target Device: -2 Count: 3
[2025-03-21 10:25:15.084, 13.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gclc-v1-fp16-128x128-2x-mlc.tz
[2025-03-21 10:25:15.084, 47.00 μs] [16c0bf000] Info | [AIE] Using CoreML CPU/GPU mode
[2025-03-21 10:25:15.088, 4.44 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gclc-v1-fp16-128x128-2x-mlc.tz is 4
[2025-03-21 10:25:15.088, 47.00 μs] [16c0bf000] Info | [AIE] resizeLoadTime: 4546 ms
[2025-03-21 10:25:15.089, 386.00 μs] [16c0bf000] Info | [AIE] gamma: 1.000000
[2025-03-21 10:25:15.089, 14.00 μs] [16c0bf000] Info | [AIE] param1: 0.146802
[2025-03-21 10:25:15.089, 7.00 μs] [16c0bf000] Info | [AIE] param2: 0.776777
[2025-03-21 10:25:15.089, 7.00 μs] [16c0bf000] Info | [AIE] param3: 0.001221
[2025-03-21 10:25:15.089, 65.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:25:15.089, 383.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 25 block(s)
[2025-03-21 10:25:15.114, 25.09 ms] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:25:15.298, 184.06 ms] [16c0bf000] Info | [AIE] resizeProcessTime: 210 ms
[2025-03-21 10:25:15.301, 2.97 ms] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Begin encode
[2025-03-21 10:25:15.318, 17.22 ms] [16c0bf000] Info | [AIE] Model: rxl_encoder1 Device: -2
[2025-03-21 10:25:15.319, 62.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:25:15.319, 17.00 μs] [16c0bf000] Info | [AIE] ---TBlockProc 120x120 C: 1/1 R: 1/1 X: 60 Y: 60 inSize: 960 960 Pad: 0 0
[2025-03-21 10:25:15.319, 223.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:25:15.319, 9.00 μs] [16c0bf000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:25:15.319, 19.00 μs] [16c0bf000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:25:15.319, 8.00 μs] [16c0bf000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:25:15.319, 8.00 μs] [16c0bf000] Info | [AIE] 1 instances for device -2
[2025-03-21 10:25:15.319, 26.00 μs] [16c0bf000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:25:15.319, 9.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_encoder1-v1-fp16-960x960-rev1-mlc.tz
[2025-03-21 10:25:15.319, 208.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_encoder1-v1-fp16-960x960-rev1-mlc.tz
[2025-03-21 10:25:15.319, 86.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_encoder1-v1-fp16-960x960-rev1-mlc.tz/analytics/
[2025-03-21 10:25:15.320, 817.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_encoder1-v1-fp16-960x960-rev1-mlc.tz/weights/
[2025-03-21 10:25:16.325, 1.00 s] [16c0bf000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:25:21.396, 5.07 s] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_encoder1-v1-fp16-960x960-rev1-mlc.tz is 6077
[2025-03-21 10:25:21.396, 71.00 μs] [16c0bf000] Info | [AIE] encLoadTime: 6077 ms
[2025-03-21 10:25:21.396, 41.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:25:21.396, 13.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:25:24.885, 3.49 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:25:24.887, 1.84 ms] [16c0bf000] Info | [AIE] encProcessTime: 3491 ms
[2025-03-21 10:25:24.887, 77.00 μs] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Finish encode
[2025-03-21 10:25:24.887, 65.00 μs] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Begin refine
[2025-03-21 10:25:25.412, 525.19 ms] [16c0bf000] Info | [AIE] Model: rxl_unet1 Device: -2
[2025-03-21 10:25:25.412, 67.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:25:25.412, 14.00 μs] [16c0bf000] Info | [AIE] ---TBlockProc 120x120 C: 1/1 R: 1/1 X: 60 Y: 60 inSize: 120 120 Pad: 0 0
[2025-03-21 10:25:25.423, 10.74 ms] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:25:25.423, 45.00 μs] [16c0bf000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:25:25.423, 23.00 μs] [16c0bf000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:25:25.423, 10.00 μs] [16c0bf000] Info | [AIE] [ -2:1 ]
[2025-03-21 10:25:25.423, 8.00 μs] [16c0bf000] Info | [AIE] 1 instances for device -2
[2025-03-21 10:25:25.423, 34.00 μs] [16c0bf000] Info | [AIE] Target Device: -2 Count: 1
[2025-03-21 10:25:25.423, 10.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_unet1-v2-fp16-rev3-mlc.tz
[2025-03-21 10:25:25.424, 345.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_unet1-v2-fp16-rev3-mlc.tz
[2025-03-21 10:25:25.424, 93.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_unet1-v2-fp16-rev3-mlc.tz/analytics/
[2025-03-21 10:25:25.429, 5.30 ms] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_unet1-v2-fp16-rev3-mlc.tz/weights/
[2025-03-21 10:26:01.547, 36.12 s] [16c0bf000] Info | [AIE] Using CoreML CPU/GPU mode
[2025-03-21 10:26:07.528, 5.98 s] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_unet1-v2-fp16-rev3-mlc.tz is 42105
[2025-03-21 10:26:07.528, 95.00 μs] [16c0bf000] Info | [AIE] unetLoadTime: 42105 ms
[2025-03-21 10:26:07.528, 25.00 μs] [16c0bf000] Info | [AIE] calculating iter 0, t=152.249039
[2025-03-21 10:26:07.528, 581.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:07.528, 21.00 μs] [16c0bf000] Info | [AIE] timestep: 152.249039
[2025-03-21 10:26:07.528, 15.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:07.528, 15.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:10.827, 3.30 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:10.827, 293.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch1: 3299 ms
[2025-03-21 10:26:10.827, 55.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:10.827, 13.00 μs] [16c0bf000] Info | [AIE] timestep: 152.249039
[2025-03-21 10:26:10.827, 12.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:10.827, 12.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:12.824, 2.00 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:12.824, 168.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch2: 1997 ms
[2025-03-21 10:26:13.072, 247.30 ms] [16c0bf000] Info | [AIE] calculating iter 1, t=76.711700
[2025-03-21 10:26:13.072, 95.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:13.072, 14.00 μs] [16c0bf000] Info | [AIE] timestep: 76.711700
[2025-03-21 10:26:13.072, 14.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:13.072, 14.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:15.108, 2.04 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:15.108, 160.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch1: 2036 ms
[2025-03-21 10:26:15.108, 44.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:15.108, 12.00 μs] [16c0bf000] Info | [AIE] timestep: 76.711700
[2025-03-21 10:26:15.108, 12.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:15.108, 13.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:17.101, 1.99 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:17.102, 161.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch2: 1994 ms
[2025-03-21 10:26:17.343, 241.72 ms] [16c0bf000] Info | [AIE] calculating iter 2, t=32.320057
[2025-03-21 10:26:17.343, 112.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:17.343, 16.00 μs] [16c0bf000] Info | [AIE] timestep: 32.320057
[2025-03-21 10:26:17.343, 14.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:17.343, 17.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:19.374, 2.03 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:19.374, 152.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch1: 2031 ms
[2025-03-21 10:26:19.374, 43.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:19.374, 12.00 μs] [16c0bf000] Info | [AIE] timestep: 32.320057
[2025-03-21 10:26:19.374, 11.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:19.374, 13.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:21.377, 2.00 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:21.377, 153.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch2: 2003 ms
[2025-03-21 10:26:21.595, 217.30 ms] [16c0bf000] Info | [AIE] calculating iter 3, t=11.302681
[2025-03-21 10:26:21.595, 213.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:21.595, 18.00 μs] [16c0bf000] Info | [AIE] timestep: 11.302681
[2025-03-21 10:26:21.595, 15.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:21.595, 19.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:23.599, 2.00 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:23.599, 170.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch1: 2004 ms
[2025-03-21 10:26:23.599, 60.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:23.599, 22.00 μs] [16c0bf000] Info | [AIE] timestep: 11.302681
[2025-03-21 10:26:23.599, 15.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:23.599, 13.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:25.591, 1.99 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:25.591, 156.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch2: 1992 ms
[2025-03-21 10:26:25.688, 96.99 ms] [16c0bf000] Info | [AIE] calculating iter 4, t=2.992514
[2025-03-21 10:26:25.689, 121.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:25.689, 15.00 μs] [16c0bf000] Info | [AIE] timestep: 2.992514
[2025-03-21 10:26:25.689, 15.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:25.689, 15.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:27.673, 1.98 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:27.674, 172.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch1: 1986 ms
[2025-03-21 10:26:27.674, 45.00 μs] [16c0bf000] Info | [AIE] conditioning_scale: 0.800000
[2025-03-21 10:26:27.674, 12.00 μs] [16c0bf000] Info | [AIE] timestep: 2.992514
[2025-03-21 10:26:27.674, 12.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:27.674, 14.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:29.645, 1.97 s] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:29.645, 159.00 μs] [16c0bf000] Info | [AIE] stepTimeBatch2: 1971 ms
[2025-03-21 10:26:29.645, 48.00 μs] [16c0bf000] Info | [AIE] Skipping last scheduler step
[2025-03-21 10:26:29.645, 25.00 μs] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Finish refine
[2025-03-21 10:26:29.645, 146.00 μs] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Begin decode
[2025-03-21 10:26:29.770, 124.81 ms] [16c0bf000] Info | [AIE] Model: rxl_decoder1 Device: -2
[2025-03-21 10:26:29.770, 71.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:26:29.770, 23.00 μs] [16c0bf000] Info | [AIE] ---TBlockProc 120x120 C: 1/1 R: 1/1 X: 60 Y: 60 inSize: 120 120 Pad: 0 0
[2025-03-21 10:26:29.771, 194.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:26:29.771, 10.00 μs] [16c0bf000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:26:29.771, 17.00 μs] [16c0bf000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:26:29.771, 10.00 μs] [16c0bf000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:26:29.771, 7.00 μs] [16c0bf000] Info | [AIE] 1 instances for device -2
[2025-03-21 10:26:29.771, 42.00 μs] [16c0bf000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:26:29.771, 16.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_decoder1-v1-fp16-120x120-rev1-mlc.tz
[2025-03-21 10:26:29.772, 1.74 ms] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_decoder1-v1-fp16-120x120-rev1-mlc.tz
[2025-03-21 10:26:29.773, 123.00 μs] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_decoder1-v1-fp16-120x120-rev1-mlc.tz/analytics/
[2025-03-21 10:26:29.774, 1.28 ms] [16c0bf000] Info | [AIE] Creating dir /Users/michaelezra/Library/Application Support/coreMLCache/rxl_decoder1-v1-fp16-120x120-rev1-mlc.tz/weights/
[2025-03-21 10:26:31.244, 1.47 s] [16c0bf000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:26:39.042, 7.80 s] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_decoder1-v1-fp16-120x120-rev1-mlc.tz is 9271
[2025-03-21 10:26:39.042, 79.00 μs] [16c0bf000] Info | [AIE] decLoadTime: 9271 ms
[2025-03-21 10:26:39.042, 267.00 μs] [16c0bf000] Info | [AIE] x_T size 120x120
[2025-03-21 10:26:39.042, 55.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:39.042, 13.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:39.130, 0.00 ns] [16d1b7000] Info | [AIE] CoreML inference failed: Unable to compute the prediction using ML Program. It can be an invalid input data or broken/unsupported model.
[2025-03-21 10:26:39.130, 65.00 μs] [16d1b7000] Info | [AIE] Not matching output sample
[2025-03-21 10:26:39.130, 14.00 μs] [16d1b7000] Info | [AIE] Error debug information
[2025-03-21 10:26:39.131, 10.00 μs] [16d1b7000] Info | [AIE] Image latent_sample Size: 120x120x4
[2025-03-21 10:26:39.131, 9.00 μs] [16d1b7000] Info | [AIE] Unable to run model with index 0 it had error:
[2025-03-21 10:26:39.132, 1.56 ms] [16d1b7000] Info | [AIE] Image Model inference failed: unable to run model with index 0
[2025-03-21 10:26:39.132, 89.71 ms] [16c0bf000] Info | [AIE] Error handling block: unable to run model with index 0
[2025-03-21 10:26:39.140, 7.81 ms] [16c0bf000] Error | Exception: "Exception: AIProcessor failed: unable to run model with index 0"
[2025-03-21 10:26:39.142, 1.54 m] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:26:39.143, 642.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:26:39.143, 16.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:26:39.143, 376.00 μs] [1f52e0840] Info | Stopping QImageViewWorker thread
[2025-03-21 10:26:39.143, 53.00 μs] [1f52e0840] Info | QImageViewWorker thread stopped
[2025-03-21 10:26:39.143, 81.00 μs] [1f52e0840] Info | Stopping QImageViewWorker thread
[2025-03-21 10:26:39.143, 36.00 μs] [1f52e0840] Info | QImageViewWorker thread stopped
[2025-03-21 10:26:39.144, 84.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:26:39.144, 11.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:26:39.217, 77.13 ms] [16c0bf000] Info | [AIE] No model info found for Enhance - RecoveryXL
[2025-03-21 10:26:39.218, 599.00 μs] [16c0bf000] Info | wantROI size: QRectF(62,2 360x360)
[2025-03-21 10:26:39.219, 1.81 ms] [16c0bf000] Info | Process round is for pre-img-optimization
[2025-03-21 10:26:39.219, 23.00 μs] [16c0bf000] Info | Image dimensions: 576 768
[2025-03-21 10:26:39.219, 9.00 μs] [16c0bf000] Info | Mat dimensions: 360 360
[2025-03-21 10:26:39.220, 183.00 μs] [16c0bf000] Info | [AIE] Output size 720x720 2.000000 2
[2025-03-21 10:26:39.220, 12.00 μs] [16c0bf000] Info | [AIE] Initializing with 124x4x720x720 RecoveryXL 576x768 2.000000 -2
[2025-03-21 10:26:39.220, 11.00 μs] [16c0bf000] Info | [AIE] desired size 360x360
[2025-03-21 10:26:39.256, 36.59 ms] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Embedding skipped
[2025-03-21 10:26:39.257, 759.00 μs] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Begin resize
[2025-03-21 10:26:39.257, 223.00 μs] [16c0bf000] Info | [AIE] Model: ggn Device: -2
[2025-03-21 10:26:39.257, 24.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:26:39.257, 16.00 μs] [16c0bf000] Info | [AIE] ---TBlockProc 128x128 C: 5/5 R: 5/5 X: 116 Y: 116 inSize: 384 384 Pad: 104 104
[2025-03-21 10:26:39.258, 352.00 μs] [16c0bf000] Info | [AIE] Model: ggn_ap Device: -1
[2025-03-21 10:26:39.258, 13.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:26:39.258, 9.00 μs] [16c0bf000] Info | [AIE] ---TBlockProc 128x128 C: 6/6 R: 6/6 X: 80 Y: 80 inSize: 384 384 Pad: 72 72
[2025-03-21 10:26:39.258, 9.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -1 from: coreml,
[2025-03-21 10:26:39.258, 7.00 μs] [16c0bf000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:26:39.258, 16.00 μs] [16c0bf000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:26:39.258, 7.00 μs] [16c0bf000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:26:39.258, 6.00 μs] [16c0bf000] Info | [AIE] 1 instances for device -1
[2025-03-21 10:26:39.258, 24.00 μs] [16c0bf000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:26:39.258, 9.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn_ap-v2-fp16-128x128-mlc.tz
[2025-03-21 10:26:39.258, 113.00 μs] [16c0bf000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:26:39.268, 10.38 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn_ap-v2-fp16-128x128-mlc.tz is 10
[2025-03-21 10:26:39.269, 597.00 μs] [16c0bf000] Info | [AIE] gamma: 1.000000
[2025-03-21 10:26:39.269, 14.00 μs] [16c0bf000] Info | [AIE] maxBlocks: 5.000000
[2025-03-21 10:26:39.269, 32.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:39.275, 5.84 ms] [16c0bf000] Info | [AIE] Auto params keys are param1 param2 param3
[2025-03-21 10:26:39.275, 32.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:26:39.275, 7.00 μs] [16c0bf000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:26:39.275, 16.00 μs] [16c0bf000] Info | [AIE] Using extra instances on M1 Pro/Max
[2025-03-21 10:26:39.275, 7.00 μs] [16c0bf000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:26:39.275, 6.00 μs] [16c0bf000] Info | [AIE] [ -3:3 -2:3 ]
[2025-03-21 10:26:39.275, 6.00 μs] [16c0bf000] Info | [AIE] 6 instances for device -2
[2025-03-21 10:26:39.275, 22.00 μs] [16c0bf000] Info | [AIE] Target Device: -3 Count: 3
[2025-03-21 10:26:39.275, 8.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn-v3-fp16-128x128-2x-mlc.tz
[2025-03-21 10:26:39.275, 74.00 μs] [16c0bf000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:26:39.307, 31.97 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn-v3-fp16-128x128-2x-mlc.tz is 32
[2025-03-21 10:26:39.307, 54.00 μs] [16c0bf000] Info | [AIE] Target Device: -2 Count: 3
[2025-03-21 10:26:39.307, 12.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn-v3-fp16-128x128-2x-mlc.tz
[2025-03-21 10:26:39.307, 36.00 μs] [16c0bf000] Info | [AIE] Using CoreML CPU/GPU mode
[2025-03-21 10:26:39.460, 153.04 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/ggn-v3-fp16-128x128-2x-mlc.tz is 153
[2025-03-21 10:26:39.460, 82.00 μs] [16c0bf000] Info | [AIE] Target Device: -3 Count: 3
[2025-03-21 10:26:39.460, 13.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gclc-v1-fp16-128x128-2x-mlc.tz
[2025-03-21 10:26:39.460, 53.00 μs] [16c0bf000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:26:39.589, 129.19 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gclc-v1-fp16-128x128-2x-mlc.tz is 129
[2025-03-21 10:26:39.589, 56.00 μs] [16c0bf000] Info | [AIE] Target Device: -2 Count: 3
[2025-03-21 10:26:39.589, 12.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gclc-v1-fp16-128x128-2x-mlc.tz
[2025-03-21 10:26:39.589, 51.00 μs] [16c0bf000] Info | [AIE] Using CoreML CPU/GPU mode
[2025-03-21 10:26:39.595, 5.78 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/gclc-v1-fp16-128x128-2x-mlc.tz is 6
[2025-03-21 10:26:39.595, 64.00 μs] [16c0bf000] Info | [AIE] resizeLoadTime: 320 ms
[2025-03-21 10:26:39.596, 381.00 μs] [16c0bf000] Info | [AIE] gamma: 1.000000
[2025-03-21 10:26:39.596, 12.00 μs] [16c0bf000] Info | [AIE] param1: 0.146802
[2025-03-21 10:26:39.596, 9.00 μs] [16c0bf000] Info | [AIE] param2: 0.776777
[2025-03-21 10:26:39.596, 7.00 μs] [16c0bf000] Info | [AIE] param3: 0.001221
[2025-03-21 10:26:39.596, 65.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:39.596, 360.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 25 block(s)
[2025-03-21 10:26:39.622, 25.61 ms] [16c0bf000] Info | [AIE] Creating cache
[2025-03-21 10:26:39.803, 181.58 ms] [16c0bf000] Info | [AIE] resizeProcessTime: 208 ms
[2025-03-21 10:26:39.806, 2.80 ms] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Encode skipped
[2025-03-21 10:26:39.806, 49.00 μs] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Refine skipped
[2025-03-21 10:26:39.806, 29.00 μs] [16c0bf000] Info | [AIE] [XLResizeEnhancement] Begin decode
[2025-03-21 10:26:39.832, 26.27 ms] [16c0bf000] Info | [AIE] Model: rxl_decoder1 Device: -2
[2025-03-21 10:26:39.833, 74.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:26:39.833, 23.00 μs] [16c0bf000] Info | [AIE] ---TBlockProc 120x120 C: 1/1 R: 1/1 X: 60 Y: 60 inSize: 120 120 Pad: 0 0
[2025-03-21 10:26:39.833, 199.00 μs] [16c0bf000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-03-21 10:26:39.833, 10.00 μs] [16c0bf000] Info | [AIE] Loading coreml backend 0002
[2025-03-21 10:26:39.833, 15.00 μs] [16c0bf000] Info | [AIE] TargetDevices: Apple
[2025-03-21 10:26:39.833, 8.00 μs] [16c0bf000] Info | [AIE] [ -3:1 ]
[2025-03-21 10:26:39.833, 7.00 μs] [16c0bf000] Info | [AIE] 1 instances for device -2
[2025-03-21 10:26:39.833, 24.00 μs] [16c0bf000] Info | [AIE] Target Device: -3 Count: 1
[2025-03-21 10:26:39.833, 8.00 μs] [16c0bf000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_decoder1-v1-fp16-120x120-rev1-mlc.tz
[2025-03-21 10:26:39.833, 99.00 μs] [16c0bf000] Info | [AIE] Using CoreML All Compute Units mode
[2025-03-21 10:26:40.110, 276.86 ms] [16c0bf000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_decoder1-v1-fp16-120x120-rev1-mlc.tz is 277
[2025-03-21 10:26:40.110, 62.00 μs] [16c0bf000] Info | [AIE] decLoadTime: 277 ms
[2025-03-21 10:26:40.110, 257.00 μs] [16c0bf000] Info | [AIE] x_T size 120x120
[2025-03-21 10:26:40.110, 55.00 μs] [16c0bf000] Info | [AIE] Updated model params
[2025-03-21 10:26:40.110, 20.00 μs] [16c0bf000] Info | [AIE] Skipped 0 block(s) out of 1 block(s)
[2025-03-21 10:26:40.200, 0.00 ns] [16d1b7000] Info | [AIE] CoreML inference failed: Unable to compute the prediction using ML Program. It can be an invalid input data or broken/unsupported model.
[2025-03-21 10:26:40.200, 62.00 μs] [16d1b7000] Info | [AIE] Not matching output sample
[2025-03-21 10:26:40.200, 14.00 μs] [16d1b7000] Info | [AIE] Error debug information
[2025-03-21 10:26:40.200, 10.00 μs] [16d1b7000] Info | [AIE] Image latent_sample Size: 120x120x4
[2025-03-21 10:26:40.200, 9.00 μs] [16d1b7000] Info | [AIE] Unable to run model with index 0 it had error:
[2025-03-21 10:26:40.200, 18.00 μs] [16d1b7000] Info | [AIE] Image Model inference failed: unable to run model with index 0
[2025-03-21 10:26:40.200, 89.55 ms] [16c0bf000] Info | [AIE] Error handling block: unable to run model with index 0
[2025-03-21 10:26:40.205, 5.18 ms] [16c0bf000] Error | Exception: "Exception: AIProcessor failed: unable to run model with index 0"
[2025-03-21 10:26:40.205, 1.06 s] [1f52e0840] Error | Attempted to serialize settings for model "RecoveryXL" .
[2025-03-21 10:26:40.206, 640.00 μs] [1f52e0840] Info | Worker cancel requested
[2025-03-21 10:26:40.206, 15.00 μs] [1f52e0840] Info | Cancelling processing
[2025-03-21 10:26:45.415, 5.21 s] [1f52e0840] Info | Opening directory: "/Users/michaelezra/Library/Application Support/Topaz Labs LLC/Topaz Gigapixel AI/Logs"
Since 8.0.2 we’ve been waiting for this “patch” for M3 Macs…I mean seriously I think our patience is getting close to running out…
This is going to be fixed in a patch coming very very soon. Stay tuned
So, neither Intel Macs nor Ventura OS are compatible?
Correct, you’re going to need to upgrade to OS14 or above to run the newest models. We’re still working with Apple on Intel Macs here …
original
https://i.postimg.cc/3NbsXgmF/IMG-13.jpg
Finale with added depth of field for background blur
I used the same technique as before
Also extreme restoration.
Any reason why Face Recovery is now limited with Redefine ( Creativity <= 2 )? It used to be available up to max level ( 6 ).
Right now Face Recovery doesn’t give great results especially on higher levels of creativity. There are some workarounds - at the moment if you export the image you can re-import it and run Face Recovery for a better result.
It sure had it’s limits even at 100 (for example, someone with an open mouth or looking sideways) but it was ok in some scenarios. Running Face Recovery after Redefine is useless as it results in an entirely different (unrecognizable) person.
Thanks - that’s good feedback. We’re definitely looking at ways to improve Face Recovery with Redefine in the future. This is particularly important for any of the more generative models.
@dakota.wixom any suggestions how to make redefine work on my machine again?
It WAS working at Creativity level 5, and now it does not, even after reinstall.
That’s a beautiful portrait! It’s definitely worth the effort. (Hornbill?)
