Errors on M1 Max:
[2025-02-06 13:53:29.870, 51.00 μs] [16c7b3000] Info | [AIE] resizeLoadTime: 312 ms
[2025-02-06 13:53:29.870, 740.00 μs] [16c7b3000] Info | [AIE] gamma: 1.000000
[2025-02-06 13:53:29.870, 11.00 μs] [16c7b3000] Info | [AIE] param1: 0.109668
[2025-02-06 13:53:29.870, 7.00 μs] [16c7b3000] Info | [AIE] param2: 0.736902
[2025-02-06 13:53:29.870, 7.00 μs] [16c7b3000] Info | [AIE] param3: 0.000488
[2025-02-06 13:53:29.870, 136.00 μs] [16c7b3000] Info | [AIE] Updated model params
[2025-02-06 13:53:29.871, 764.00 μs] [16c7b3000] Info | [AIE] Skipped 0 block(s) out of 54 block(s)
[2025-02-06 13:53:29.897, 25.97 ms] [16c7b3000] Info | [AIE] Creating cache
[2025-02-06 13:53:30.265, 367.68 ms] [16c7b3000] Info | [AIE] resizeProcessTime: 395 ms
[2025-02-06 13:53:30.270, 5.06 ms] [16c7b3000] Info | [AIE] [XLResizeEnhancement] Encode skipped
[2025-02-06 13:53:30.270, 118.00 μs] [16c7b3000] Info | [AIE] [XLResizeEnhancement] Refine skipped
[2025-02-06 13:53:30.270, 33.00 μs] [16c7b3000] Info | [AIE] [XLResizeEnhancement] Begin decode
[2025-02-06 13:53:30.289, 19.04 ms] [16c7b3000] Info | [AIE] Model: rxl_decoder1 Device: -2
[2025-02-06 13:53:30.289, 75.00 μs] [16c7b3000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-02-06 13:53:30.289, 16.00 μs] [16c7b3000] Info | [AIE] —TBlockProc 120x120 C: 2/2 R: 3/3 X: 60 Y: 60 inSize: 180 240 Pad: 0 0
[2025-02-06 13:53:30.289, 164.00 μs] [16c7b3000] Info | [AIE] Selecting backend for device -2 from: coreml,
[2025-02-06 13:53:30.289, 9.00 μs] [16c7b3000] Info | [AIE] Loading coreml backend 0002
[2025-02-06 13:53:30.289, 17.00 μs] [16c7b3000] Info | [AIE] TargetDevices: Apple
[2025-02-06 13:53:30.289, 8.00 μs] [16c7b3000] Info | [AIE] [ -3:1 ]
[2025-02-06 13:53:30.289, 7.00 μs] [16c7b3000] Info | [AIE] 1 instances for device -2
[2025-02-06 13:53:30.289, 25.00 μs] [16c7b3000] Info | [AIE] Target Device: -3 Count: 1
[2025-02-06 13:53:30.289, 9.00 μs] [16c7b3000] Info | [AIE] Loading default model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_decoder1-v1-fp16-120x120-mlc.tz
[2025-02-06 13:53:30.290, 106.00 μs] [16c7b3000] Info | [AIE] Using CoreML All Compute Units mode
[2025-02-06 13:53:30.408, 118.78 ms] [16c7b3000] Info | [AIE] Loading time for model file /Applications/Topaz Gigapixel AI.app/Contents/MacOS/../Resources/models/rxl_decoder1-v1-fp16-120x120-mlc.tz is 118
[2025-02-06 13:53:30.408, 62.00 μs] [16c7b3000] Info | [AIE] decLoadTime: 120 ms
[2025-02-06 13:53:30.409, 681.00 μs] [16c7b3000] Info | [AIE] x_T size 240x180
[2025-02-06 13:53:30.409, 92.00 μs] [16c7b3000] Info | [AIE] Updated model params
[2025-02-06 13:53:30.409, 40.00 μs] [16c7b3000] Info | [AIE] Skipped 0 block(s) out of 6 block(s)
[2025-02-06 13:53:30.504, 0.00 μs] [16e707000] Info | [AIE] CoreML inference failed: Unable to compute the prediction using ML Program. It can be an invalid input data or broken/unsupported model.
[2025-02-06 13:53:30.504, 63.00 μs] [16e707000] Info | [AIE] Not matching output sample
[2025-02-06 13:53:30.504, 14.00 μs] [16e707000] Info | [AIE] Error debug information
[2025-02-06 13:53:30.504, 10.00 μs] [16e707000] Info | [AIE] Image latent_sample Size: 120x120x4
[2025-02-06 13:53:30.504, 8.00 μs] [16e707000] Info | [AIE] Unable to run model with index 0 it had error:
[2025-02-06 13:53:30.504, 19.00 μs] [16e707000] Info | [AIE] Image Model inference failed: unable to run model with index 0
[2025-02-06 13:53:30.504, 95.03 ms] [16c7b3000] Info | [AIE] Error handling block: unable to run model with index 0
[2025-02-06 13:53:30.504, 35.00 μs] [16e707000] Info | [AIE] Model Backend state is invalidated due to previous errors
6 13:53:30.504, 17.00 μs] [16e707000] Info | [AIE] Image Model inference failed: unable to run model with index 0
[2025-02-06 13:53:30.504, 23.00 μs] [16e707000] Info | [AIE] Model Backend state is invalidated due to previous errors
[2025-02-06 13:53:30.504, 13.00 μs] [16e707000] Info | [AIE] Image Model inference failed: unable to run model with index 0
[2025-02-06 13:53:30.504, 101.00 μs] [16c7b3000] Info | [AIE] Error handling block: unable to run model with index 0
[2025-02-06 13:53:30.504, 14.00 μs] [16e707000] Info | [AIE] Model Backend state is invalidated due to previous errors
6 13:53:30.504, 12.00 μs] [16e707000] Info | [AIE] Image Model inference failed: unable to run model with index 0
[2025-02-06 13:53:30.504, 19.00 μs] [16e707000] Info | [AIE] Model Backend state is invalidated due to previous errors
[2025-02-06 13:53:30.504, 30.00 μs] [16c7b3000] Info | [AIE] Error handling block: unable to run model with index 0
[2025-02-06 13:53:30.504, 7.00 μs] [16e707000] Info | [AIE] Unable to run model with index 0 it had error:
with index 0
[2025-02-06 13:53:30.504, 22.00 μs] [16e707000] Info | [AIE] Model Backend state is invalidated due to previous errors
[2025-02-06 13:53:30.504, 10.00 μs] [16e707000] Info | [AIE] Unable to run model with index 0 it had error:
[2025-02-06 13:53:30.505, 15.00 μs] [16e707000] Info | [AIE] Image Model inference failed: unable to run model with index 0
[2025-02-06 13:53:30.505, 59.00 μs] [16c7b3000] Info | [AIE] Error handling block: unable to run model with index 0
[2025-02-06 13:53:30.509, 4.89 ms] [16c7b3000] Error | Exception: “Exception: AIProcessor failed: unable to run model with index 0”
