I had viewport pixelation with 5.6.x releases. The 5.7.x releases cured that for me. The newer models released after 5.4.5 don’t seem to generate as much (if any) new detail as before, so many upscales don’t seem as sharp. The newer models seem to focus more on improving existing detail.
Can’t have Client A sitting (or Zoom) next to me as I open files and they see a file related to Client B. Veeerrrry bad business move. Can’t take that chance. I MUST clear that list.
Yeah. I have some programs that provide the option to retain recent docs or clear them.
I usually have the inverse issue. I typically hate hunting to find what I recently worked on and want the list handy…
There’s actually a place on the Topaz Discussion Forum (it may be under Products or New Products) where you can suggest features & others can ‘vote’ them up if interested also to help developers decide if a common enough interest to prioritize. If I can find the link I’ll edit this to post & insert it for your convenience…
Just an upvote on fixing the problem with comparison view. Right now, it’s impossible to compare Standard Model with Low Resolution model because only the upper left quadrant is selectable and the other 3 are ‘hard wired’. Thanks! [It works fine in the standalone version but not in the Photoshop plugin]
Glenn -
On my Windows 10 box I can’t reproduce your issue. I can assign any method to any preview window. I select any preview window, then select a method, and window changes to that method while the others remain unchanged.
The exception is when the Original switch is active, then the upper left is stationary with the Original. The remaining three can be changed at will.
Hello dear Fotomaker, thank you very much for your concern, unfortunately, there’s no link for this version on the release page, the links begins with version 4.5.0, how can I open a support ticket please?
We just opened the presents that Santa left. So, perhaps, in my elation I’m missing something about where to open a support ticket. It seems the design of the Topaz site has changed.
I’d recommend you start on this page & choose the option to “Contact Us” (upper right). You should get a pop-out box (see lower right near what looks like a speech bubble to me…) that will let you send a note to Topaz staff. See my snip of how it looks:
If the Topaz staff are off for the holidays (today is Christmas) and some companies shut down or do limited work the week b/wn Xmas and New Years - you may not hear back right away b/c of the holiday schedule. I can’t tell you what it is there.
Be sure you include any relevant info in the note at the site I pointed out above so you can get a useful reply ASAP. That means include info like your OS so they can link you to a correct installer. And, just to be pre-emptive (and anticipate a question I know I’d ask if I were them) mention why you want to go back to that pretty long ago version. I don’t need to know. But, as a s/w company, they might be interested to know your motivation(s).
BTW, I would be interested to know which OS you’re running (Win which one? Apple which one?).
On my Win 10 PC. Using Ps 2022 as my appln host (Automate > GAI) for the GAI 5.7.3 rel. plugin.
I can Only change the upper left quadrant
The other 3 quadrants are unchangeable when I click on them then try to click on another model in the righthand Settings Panel to swap in a different GAI model.
I have my Preferences set to auto-download any models I don’t already have downloaded.
This is not the way my plugin worked in previous releases. In past, I could change any/all models (in Comparison View) to desired upscaling models.
Also, prior to the most recent several releases (for all the current AI products) I never had the issue (Standalone & Plugins) of getting an initial view with duplicate models showing up in multiple quadrants. The older programs displayed a discrete model in each quadrant. Which was how it should be (& is preferable); with the option to customize as desired.
I have an old Os and computer HP Elite BX383AV:
Application & Version: Topaz Gigapixel AI Version 5.3.2
Operating System: Windows 7 Version 6.1 (Build 7601: SP 1)
Graphics Hardware: NVS 300/PCIe/SSE2
OpenGL Driver: 3.3.0
CPU RAM: 16342 MB
Video RAM: 512 MB
Preview Limit: -2147483648 Pixels
I tried Gigapixel version 5.6.1 and have strange colored artefacts in some pictures,
I’m quite satisfied with 5.3.2 version, but heard in some posts that many users recommend
version 4.4.5, so I wanted to give it a try and compare the results with my old computer,
It’s the main reason (and secondary the treatment speed of image also)
Pls. send the info you included just above at the Spt site I pointed you to. It should be helpful to the developers. I’m “just” a user. Like you.
I’m also a hoarder. That’s why I asked which OS. I’m a Win user also. But Win 10. I have the online installer for the version you seek. I attempted to upload it. But it’s not a file format I can upload to this discussion forum. The Topaz folks will be able to send you the link directly. They’re very nice.
