My computer specs.
Windows 10 Pro 64-bit Version 1903
Alienware Aurora R8 9th Gen Intel® Core™ i9 9900K (8-Core/16-Thread, 16MB Cache, Overclocked up to 4.7GHz on all cores)
NVIDIA® GeForce RTX™ 2080 Ti GDDR6 (Over Clock Ready)
Installed Memory (RAM) 32GB Dual Channel HyperX™ DDR4 XMP at 3200MHz
850W EPA Bronze PSU Liquid Cooled Chassis
Photoshop CC Version 21.1.0 release
Internet provider Century Link fiber optic Gigabit
Testing for Gigapixel AI 4.9.4.1
Download and Install worked perfectly from full install and online installer.
Brought in 7 images to test.
Fixes:
Controls do stay the same when opening or selecting another image.
Controls are not resetting to the default (2x scale) when one image closes and another open.
Scaling options appear to stay the same after switching between units.
Not noticing a rounding issue when doing unit conversions.
Adobe RGB color profile is written out to meta data correctly.
Has this been a problem for you in past versions or is it this version specifically?
Could you confirm that the output is worse than the preview in a photo editing program like Photoshop? Windows Photo Viewer and the Windows “Photos” app both seem to make images fuzzier by default. I was able to replicate your issue but I’m not noticing the fuzziness when viewing it in Photoshop, in particular.
I don’t know, i started using this program from the 4.9.3, but i didn’t look the details until now. I just recognized this problem.
I opened the output file in photoshop and with the other windows image viewer,paint, third party viewers. All the same.
But i see not only me suffer from this problem. So many users reported it. I tried now 2x 4x 6x and i don’t see any differences on the pictures expect the size of the file. That’s interesting.
On my system, the output look as it should I think, v4.9.4.1, OpenVino mode (No noticeable difference with GPU enabled, latest stable AMD driver installed):
No changes. Trunaround between Capture One 20 (Sony) and Gigapixel AI still does not work. Gigapixel does the processing, but when it should return to Capture One I get the beachball of death. Protocol below:
Date/Time: 2020-06-12 21:58:15 +0200
End time: 2020-06-12 21:59:15 +0200
OS Version: Mac OS X 10.15.5 (Build 19F101)
Architecture: x86_64h
Report Version: 29
Data Source: Stackshots
Shared Cache: 0x4e4d000 B8C8D6CA-9D23-3876-BB41-16E5BE6A5E58
Files quality_9.jpg and quality_10.jpg are identical
This means Gigapixel (and presumably other Topaz products) output Quality 10 whenever Quality 9 is chosen. Also makes me wonder if Quality 8 is actually the real Quality 9. It’s possible that there is some “Slider value +1” math bug in the code.
No problem. I just checked a few more qualities. They all shrink in size. Definitely looks like a “take the slider value, add +1, cap at 10” code issue.
Thanks for the quick reply. Looking forward to a fix.
By the way I have a quick question: Does the neural network model change with new/improved training between versions? I just upgraded from 4.4.5 to 4.9.4.1 and I imagine I’m seeing better quality from the 4x scaling mode. I used to think that 4x gave too much artifacts but now I like it. Maybe I am just imagining things.
I’m just submitting a reminder about the Autoupdate bug (admittedly in 4.9.4.0 but it should be obvious why I have to report it here).
Gigapixel AI told me there are updates available:
However, clicking “yes” leads to the error:
and closes the Gigapixel app.
Also, finding Autoupdate.exe then double-clicking it leads to the Updater app finding an update, but
and finally:
Now I realise there are other ways to download, so no one needs to tell me that
I think it could just look better than having this bug me (almost) every update.
They do not. We haven’t updated the AI model in a few months (the AI takes much longer to train than doing UI updates / fixes). I try to be as explicit as possible in the changelogs, so any back-end changes like that will definitely be posted.
We are planning a model update at the end of the month actually, which is going into beta testing here on the forums in the next few days. If you’d like to join and help us test out the changes, feel free to drop me a PM!
What is telling you that the file is 72ppi? Are you on pc or mac?
When I take a 300ppi TIF and output after upsizing either a TIF or a JPG, both files are still marked as 300ppi (checked in Photoshop and Windows file UI).
