Thanks for your reply Don…the system restored itself automatically, although it may be that a few things were overlooked. Everything else seems to work fine otherwise so wasn’t sure if it was Topaz specific. Will create a ticket
I was having the same dll and GetThreadDescription issues as well. Thankfully my support ticket was eventually answered and it looks like a patch has been issued. I was instructed to uninstall and re-install and since then I haven’t had issues. So if you’re having the same problem as above without a solution yet, try uninstalling and re-installing.
Hi Raymond, thanks for your reply…the devs were fairly quick in getting back to me with a patch as well…it turned out that I had to bite the bullet and clean install Win10 anyway, so in my case the problem was resolved. Thanks again!
Hello, after upgrading to 4.4.3 I have the same problem in Windows 8.1. Uninstalling and re-installing did not help either. Fortunately, I created a restore point and reverted to version 4.4.1, which is fine.
