👋 General | Category Guidelines | Photo AI
Support Request
If you encounter an issue or have a question about Photo AI, the fastest way to reach us is to email help@topazlabs.com.
This will open a support ticket with us, and we’ll help troubleshoot the issue with you. :blush:
In your email, please include the following details:
  • A detailed description of the issue or behavior you’ve encountered. The more specific you can be, the better — it helps the team quickly identify the root cause and begin the troubleshooting process.
  • The version of Photo AI you are using.
  • Any relevant screenshots, if necessary
  • System Profile Information
    How To Obtain Your System Profile (Mac)
  • Log Files
    – To gather logs, open Photo AI, go to the menu bar on top, and then go to Help > Open Log Folder.
SYSTEM REQUIREMENTS
Before sending us an email, please make sure your machine meets the minimum requirements for Photo AI:
If you would like us to confirm, send us your full system profile information:
TO POST A FORUM TOPIC
If you prefer to post on the Community Forum, feel free to do so :slight_smile:
Other users may pitch in, and we can help investigate the issue as well. The fastest way to get assistance is to reach out to help@topazlabs.com.
Make sure to check any posts already on your question or issue in the Ideas or Bugs and Issues threads to know if this is a known issue or suggestion, and test any workarounds posted in the threads, if available!
