Framerate-Conversion generate Double Frames!
I try to convert a 25fps File to 60fps… (I have tried Chronos, Apollo etc.)
Video AI is not able to make a smooth Motion, it generates randomly repeated/doubled Frames…
Have you used the replace duplicate frames option?
In the Original-Video there are no doubled Frames…
And also the Option “replace Duplicate Frames” don’t solve this Issue
After some intensive Tests:
ALL Models (Apollo, Apollo Fast, Chronos, Chronos Fast) generate randomly Doubled Frames…
Thanks for the follow up, can you share the input file and the TVAI export
You can securely submit your files(s) to our Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Submit File to Dropbox
Hi :wink:
I have now uploaded the original mxf (ProRes) File and the rendered Result (mov File).
I have also attached s Screenshot from my Settings which I have used for the Framerate-Conversion.
You should see that the Frame is skipping every few Frames
Are you referring to the flickering you see over the watermark? This does not happen when I process the file on my end using an owned license. The repeat frame that occurs every so often is a result of interpolating the frames.
No I mean the doubled Frames!
Click Frame-by-Frame through the Video and you see randomly there are doubled (repeated) Frames.
But with Frameinterpolation there should be NO repeated Frames visible!
Yes, I do see that as well :frowning: We are working on this issue :slight_smile:
