If you are posting a new bug, please include the following]
The bug / behavior you have encountered:
The “Frame rate” listed for a video sometimes repeats infinitely.
For example, I currently have five videos open in Topaz Video AI. When I mouse over them, videos in position 1 and 3 have FPS listed at 29.97002997002997, but videos in position 2, 4 and 5 have FPS listed at 29.97
At first I thought this bug only occurred with every other input video, but the fact that the fourth and fifth video I opened display properly, leads me to believe this bug is a bit more random.
Your system profile: Topaz Video AI 5.3.1
Your log files (Help > Logging > Get Logs for Support): N/A
Any screenshots as necessary:
Probably not a bug. You would have to look at the file metadata to see how the frame rate has been stated there. That particular NTSC frame rate is normally defined as 30 x (1000/1001) which works out as 29.97002997002997, so 29.97 is an approximation.
So the display isn’t wrong, just showing too much accuracy perhaps.
I have a small sample from an NTSC DVD that also shows 29.97002997002997 in TVAI:
The way frame rates are defined also relates to drop frame and non-drop frame timescode, but that’s a complication I won’t go into. Here’s a starting point:
