The following instructions detail how to use Frame Interpolation in DaVinci Resolve.
Frame Interpolation for Resolve is available in Video AI 5.1 Beta.
- Drag-and-drop a clip onto the timeline.
- Copy-and-paste the clip to match the slow motion rate you’d like to use. For example, 3x slow motion requires 3 clips lined up on the timeline.
Select all of the clips, right-click, and select “New Compound Clip…”
Apply Frame Interpolation from the Plugins panel and select a model and slow motion rate from the Effects panel.
