This happens when cropping and using face recovery
Sorry it took me a while, had a busy week. Just sent it your way via Dropbox. Thank you!
I would like to see if updating your GPU driver will resolve the problem.
Please use the following link to update your driver: NVIDIA | GeForce RTX 2080 | Studio Driver Update
I’m on the latest driver for my 2080Ti, 551.86 released March 18th
Thanks for that update.
- The original image file.
- The processed image.
- A screenshot or description of the settings panel so I can see what adjustments were turned on. Please include the crop parameters you are using.
Just uploaded the files!
Thanks for sending in those files, I was not able to replicate this issue you were reporting on my machine. We have just released a new version today so let’s try updating you to see if this resolves the issue.
Try using the following link to update:
Thanks for all the help John. I’ll give this a shot and do a fresh install as well just to make sure I don’t have any missing or corrupted files.
If you guys implement a diagnostic tool to log data and use through the app, I bet that would be great moving forward for troubleshooting and implementing fixes. I know some software you can go into diagnostics mode and work normally and it will track everything into a separate file to send over later.
Just an idea. I hope you have a great rest of your day, John!
