Extraordinarily slow
I am using a macbook pro with M1 Pro,16GB, and Sonoma 14.1 and just purchased the upgrade to version 3.0.1
for some reason the software is running so slowly to be almost unuseable on a scanned image 2668x4128 pixels scanned and saved asb a JPG changing to another image makes no digfferernce
I am sure that when i first started to use Topaz it worked very well and really fast
Topaz Labs Download Page
