Launching Topaz from Lightroom to process a .ORF (OMSystem RAW) photo works. However: “Save to Adobe Loghtroom Classic” produces ERROR: DNG Write Error.
Topaz Photo AI [v2.4.0] on [Windows 11]
Which camera model are you using to create these .ORF files?
OM-1 Mark II from OMSystem
The OM-1 Mark 1 (i.e. the ORFs generated with the first version of the camera) are working fine. Interestingly the ORF pictures generated with the Mark II are opened and treated correctly. Its just that they can’t be stored.
I have the same Problem as described above. Camera OM-1 Mark II, Mac Studio M1 Max, Max OS Ventura 13.6.5
@wild_shutter @m.falldorf-701566
The OM-1 issue was fixed in the latest version release, v2.4.1
I was on v2.4.0 and just got the update to v2.4.1 promted today. I can confirm it works. Thanks.
