.dng photo crop
Photo is becoming cropped without any reason. The original photo is added below and the screenshot is the way it is cropped on (zoom = fit). This was not an issue on the earlier version, but I just upgraded the version.
Steps to reproduce issue:
  1. Download .dng file from Lightroom CC
  2. Upload to Topaz Photo AI (Don’t use Plug-in)
  3. See crop image
    DSC02173.dng (14.8 MB)
Topaz Photo AI [2.1.3] Macbook Air M2 MacOS Sonoma 14.1.2
I experience the same problem on version 2.2.1 M1 Macbook with Sonoma 14.1
Some pictures always get cropped, even though I never wanted that. Very annoying when batch processing, as I have to recheck every file for possible subject difference.
@yash.mehta Have you tried to upgrade to the latest version (currently 2.2.1)?
I noticed you are using 2.1.3 maybe the bug was fixed.
it wasn’t
I downloaded your image and ran it through TPAI. I also got the crop. There must be something about this DSCO file, or it it happening with others? I have not had it on any of my files, whetherARW, TIF or JPG.
I also ran the image through Topaz Sharpen AI and there was no issue.
You need to send your logs and the original file to Support for them to investigate.
M1 Mac Mini, 16GB, Sonoma 14.3.
I haven’t seen the issue pop up in the recent update (2.2.1), so I assume it’s fixed. But it might be this file, it works if I go through my normal workflow from LR CC → Photoshop → Automate(Topaz AI)
Whatever it is, it is not fixed. At least on a Mac. But I suspect it IS to do with this particular file. Have you tried it yourself? Konrad did upload it for others to test!
I found out that this only happens when I crop an image in Lightroom and export the DNG to Topaz. So maybe Topaz takes the original file size, not the altered one as a base…
Glad you resolved it
unfortunately nothing is resolved, I just know the bug better. topaz still has to fix it.
I have tried it with the file I posted above, still happens if I go straight to TPAI without the plugins.
Strange, I haven’t encountered that issue before, but I was having the problem with an uncropped image raw becoming cropped :frowning:
@malte.widenka Have you tried contacting the Topaz support team directly and brought this to their attention? This is certainly an odd one.
I opened the picture in a few other apps and it behaved differently but only TPAI has that tight crop.
When I open the picture on my end the logfile shows
[2024-01-03 19:27:09.738, 6.00 μs] [16ced7000] Warn | No default crop origin found in EXIF data
[2024-01-03 19:27:09.743, 14.82 ms] [1d9241000] Info | [ImageData] Setting floating crop ROI: QRectF(0,0 1x1) 844 1280 QSize(844, 1280)
[2024-01-03 19:27:09.743, 11.00 μs] [1d9241000] Info | [ImageData] Set internal crop ROI to: QRect(0,0 844x1280) 844 1280
Which I find weird … where is the crop information coming from?
Also when I look at the picture metadata in XnView there are a few warnings.
Consider reaching out instead of waiting.
@Konrad82 yes, I did and we found the issue this night. There is a bug in the lens correction part, if I turn this off in the topaz preferences, everything is fine. Since the lensecorrection is already done in Lightroom, there is no need anyway. so this is fine for me now.
