DeNoise 3.2
If you encounter problems with the Nvidia control panel.
You have to uninstall it via Apps in Windows and install it again via the Windows Store.
I think it’s a disaster how Nvidia is handling this now.
I have an NVIDIA GeForce RTX 2070 with Max Q Design.
I upgraded the driver to Studio 472.12 9/20/2021.
I upgraded to DeNoise 3.2.0 just now.
All models now run OK with GPU High.
Performance is very good.
Finally!
Thanks, Thomas.
I updated this thread to indicate success with my installation and testing.
The lesson here is to stick with this 472.12 driver and don’t update it. I see nothing but trouble with Nvidia cards (so I use AMD). If it works don’t fix it.
