DeNoise 3.0
May be the Cuda Libs.
The right-click from explorer is treated as a plugin call.
The plugin mode will not overwrite a RAW image but will overwrite a DNG, TIF/TIFF, JPG/JPEG or PNG.
DeNoise AI Ver.3.0.1 seems to be too aggressive. It makes contours blurry, even with minimal values of settings.
Original
Result
Settings:
The result is better in “Low Light” Mode, but it causes color halo’s that look like wide chromatic aberrations.
But it works really faster than previous versions.
PS By the way, everything has been installed and worked properly.
5
I’m having trouble with DNAI v 3.0.0 and 3.0.1 on an Intel Mac Mini, running Catalina with all updates. I’ve opened a ticket with Support, I’m posting here to see if anyone else has seen the issue and might have a fix.
DNAI launches normally. After the launch process concludes, any keyboard (or trackpad) input causes the output frame (split view) to exhibit images that have nothing to do with the input. At the same time, all text in the window is replaced with whiteout blocks. Have done 3X shutdown/restart/reinstall, no change. The prior version worked fine on this machine.
Anybody seen anything like this? Any ideas for troubleshooting? Thanks.
I don’t know what you changed but this version is nearly unusable. Running updated WIndows 10. I’ve tried turning GPU on and off. It takes an average of 15 seconds for the preview to update. If I am in comparison that’s 45 seconds. While the preview update is processing I can’t pan or move another slider.
Very disappointing release. Installed/reinstalled (full install) it twice and still couldn’t make it work. It is hanging on Applying changes. No progress bar. Rolled back to previous release that is also faster on Preview that the 3.0.1. I have CC and HP Spectre
This version 3.01 should never have been out of Beta.
Same issue for me too.
Which Intel Mac Mini?
Wich GPU driver do you use. The RTX 2XXX card can’t make use of the driver of the Quadro Card.
But the Quadro can use the RTX / Geforce drivers.
You should use the actual Studio Driver with both.
Nvidia 2080Ti, latest drivers installed, Windows 10 and DeNoise 3.0.1 hanging when applying changes (launching from photoshop). Ended up having to do a system restore to get the old version of DeNoise AI back
I’m very content with the new Version. I use the LowLight model in auto mode 99% of the time (on un-denoised and un-sharpened jpgs developed with Capture One from RAW), and the results look very natural. Faster preview is a big plus as well.
The only downside is low-frequency color noise which the LowLight model doesn’t get rid of very well. A slider solution for this in the post processing section would be great (the existing color noise slider tackles low-frequency color noise which leeds to decolorization of small details).
Or you just down load it in the forum.
I think its a bit faster than a system restore.
Quick tip, set C1 color denoise at least at “1”.
And Denoise Detail at “30”.
Thanks a lot! Yes, setting color denoise to 1 makes a big difference. That said, some pictures still suffer from very coarse colour noise. I can live with that, but hopefully this gets tackled in one of the future versions :slight_smile:
The 2018 design, bought last year. 64GB RAM, 2TB SSD.
Most of the problems we had in the beta were with GPU drivers older than half a year.
I would check if there is any update from Apple for the mac mini.
Or you have chosen the wrong version, for Apple there is also a legacy version.
You can try to accommodate denoise with Capture One, they can complement each other.
But above a certain value of luma denoise, the noise becomes detail.
I am sure of that.
You are a beta tester. Did you contribute to the testing for this product?
OK, I understand, but I believe the earlier behavior (like with Topaz Adjust AI) is the correct one. Or the ability to save as… should at least be made a preference option. I am not a fan of taking functionality away :wink:
