Colour issues using Upscaling and IRIS
Dear all,
While upscaling SD footage 4x up using IRIS interlaced from 25 to 50fps, there are colour issues in bluish parts of the video (water and sky). While scaling up 2x, the issue disappears.
Thank you for your analysis.
Best regards,
Andy
Hi Andy,
Thanks for reporting this error. Would it be possible to get the original video uploaded to our Dropbox for testing?
You can securely submit your file(s) to our Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Submit to Dropbox
Dear Tony,
Thx for having a look at the raw material I just uploaded. Probably it has something to do with high Anti-Aliasing values in combination with 4k resolution, as lower values does not come with this blue effect.
Addionally, I enclosed a video which is adressed here.
Thank you very much!
Best regards,
Andy
Thanks for uploading! I’ve sent this example (and the other example with the freckles) to our dev team for review.
