Lightroom Classic 13.2 Topaz 2.4.1 Mac Mini M1 2020
Every time I send an image from Lightroom through Topaz, it shifts markedly to magenta, and also adds a fisheye distortion to the image. Is there a workaround? I see this issue arising in many queries dating back over a year
Can you confirm with me which Lightroom plugin you are using:
- The RAW plugin, accessed through File > Plug-in Extras > Process with Topaz Photo
- The External Editor plugin, accessed through Photo > Edit in > Topaz Photo AI
Also go to Preferences > General and ensure that you have Lens Correction enabled.
- The original image file.
- The processed image.
- A screenshot or description of the settings panel so I can see what adjustments were turned on.
Dropbox File Request
am sending several files. one is the correction setting - just a lot of lensblur correction.
Then the original camera RAW file, and the result. I notice that now when it gets taken into Lightroom, the color change is now automatically corrected for.
Normally I grade first, then send to Topaz. For that process, I placed the graded original, then the result. Usually this loses the reframing, so I paste the settings in, which bypasses the automatic color adjustment.
The automatic adjustment is new, but the distortion is the same.
Thank you!
Jonathan
jonathan.keeton | jonathan.keeton@gmail.com | 415 760 0174 | www.jonathankeeton.com | instagram: jonathan.keeton | skype: jonathan.keeton
