Codec Settings Unstable
v6.0.0 Windows 11
Codec settings are being reset unexpectedly when switching tabs.
Video constant bitrate , the target bitrate number and container type seem to reset to defaults.
Steps to reproduce.
In the codec settings,
set output type video, H.265, main10
Set Bitrate to constant, Target bitrate 50, Container type mkv
Change from the Video to Image sequence options then back to Video; Video settings have been reset to Dynamic and Container=mov
Also it’s not clear to me whether all of the Codec settings should normally be saved in the Presets, I seem to keep losing the constant bitrate setting, repeatedly entering the same constant bitrate and saving the preset again.
James, thanks for sharing. Sending a note to the devs to look into this and get it resolved.
