Hello everyone,
my issue is basically described in the thread name. I cant export Videos anymore since 3.3.1 because somehow the input is not recognized correctly anymore. Completely uninstalling Topaz and reinstalling solves the problem but only for one encode. So i guess it has something to do with caches/temps?
I reverted to 3.3.0 and everything works fine there.
Screenshot look at the IN section to the right:
DxDiag.txt (146.2 KB)
UPDATE: I think i found the issue. it seems it was the default preset i was using. As soon as that 1 preset was used as default it bugged the input. Deleted the preset and recreated it. Seems to be working for now.
