the ai produces wrong purple color from olive feather of a bird. if i change setting to raw remove noise - normal, it is correct. my raw photo is a sony ai .arw file.
DSC02971.ARW (52.5 MB)
@iamlkk38 Thanks for uploading that. I was not able to reproduce the artifacts on my computer, which leads me to suspect it’s a hardware issue.
OK,system profile attached.
Tim He via Topaz Community <noreply@topazlabs.com> 於 2023年5月25日 週四 上午6:15寫道:
DxDiag.txt (100 KB)
Thanks for uploading that @iamlkk38.
It looks like the graphics card drivers haven’t been updated since 2021.
Use this link to update: https://us.download.nvidia.com/Windows/535.98/535.98-notebook-win10-win11-64bit-international-nsd-dch-whql.exe
Then try running Photo AI again and see if it fixes things.
@tim.he thanks for your suggestion about graphics card drivers, I’ll try it and reply to you.
