Bright dots and texts artefacts in Proteus
Hi Topaz Labs,
Using Proteus on FHD contents to upgrade them to UHD, I noticed in very dark scenes or black screens (between two parts of a TV show for instance), a constellation of white or coloured glowing dots / points.
It may be triggered by hidden compression artefacts or hidden details in the darkness, but very annoying.
Proteus is good for still texts with modern typeface, but poor for oldtime looking typefaces or scrolling up texts.
Should be fixed because these artefacts are extremely visible!
Multiple bright dots glowing in the darkness are very visible indead.
Best regards.
Vincent.
Are you seeing this in Video AI or the new app Topaz Video?
Can you send a screenshot of what you are seeing in the app to the support team at help@topazlabs.com for further review?
