Hello,
I’m having a H265 video with 17MBps Bitrate (1080p) and I’m trying to upscale it to 4K. So I thought, if the image is bigger, the bitrate should as well. But no matter what constant Bitrate I set, it’s still 17MBps in the end (checking using Media Info).
Any idea what I’m doing wrong?
In the export settings are you using the dynamic or constant option for the bitrate?
Can you recreate this issue and then share the logs? Also, is it more than one file that this is occurring with?
In the logs I am seeing different bit rates for the exported files that match what you are setting the constant for.
I wonder what mediainfo shows for both files?
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Duration : 25 min 25 s
Bit rate : 17.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.086
Stream size : 3.02 GiB (89%)
This is media info for the re-encoded file.
This is for the original file:
Video
Format : HEVC
Format profile : Main 10@L4@Main
Width : 1 920 pixels
Height : 1 080 pixels
