Batch processing vids issues
Having lots of issues now with batch processing videos.
Some of the issue that crop up:
– Sometimes vids that should only take 1 -2 min to render end up taking hours to render. This even includes vids that are super short like less than 30 seconds long.
– Sometimes vids end up getting rendered upside down.
– Sometimes vids get rendered 90 degrees rotated, resulting in a stretched video.
For all these issues, I can stop the rendering process, and restart, and it’s fixed.
But this totally negates the benefits of batch processing.
I’m stuck checking my computer often now just to make sure it doesn’t get stuck in long rendering times or outputs something that looks weird.
This pretty much happens to every batch process I run now. Been like this for several weeks.
The typical things I’m doing for all vids are:
Proteus enhancements
2x upscale
60 FPS via Chronos
Codec Setting Bitrate Constant 24
System:
PC
Windows 11
64 RAM
AMD Ryzen 9 7900x
NVidia 4060
logsForSupport.zip (1.1 MB)
Hi John,
Thanks for the logs, can you reach out to our support team at help@topazlabs.com and upload one of the videos that is rendering upside down (original and exported out of video) to my dropbox so we can look into this?
Submit File to Dropbox
Please link this thread in your support ticket so we refer to these logs as well and dig into the speed issue.
