Audio mode not saved in preset
V 5.0.2
When saving a preset and audio mode is to convert, the audio mode settings are not saved and remain on copy.
When you made the preset did the box get checked for it to include the Preview and Export settings?
Can you tell me what the preset settings were, so I can try to recreate it on my end?
Yes it did when creating a new profile. I also tried to modify an existing profile and the results were the same.
Are you on a mac or PC system? What settings did you set in the preset?
On a PC.
Screenshots and the log are attached.
2024-04-29-13-29-4-Main.tzlog (1.7 MB)
