Artifacts in all images processed on auto
Steps to reproduce issue:
  1. Step 1 open raw file in Adobe Raw on Mac and eliminate all sharpening and denoise
  2. Step 2 open in PS, make new layer and runTopaz AI from PS filter
  3. Step 3 run on auto which has removing noise on and sharpening off, which leaves image insufficiently sharpened, than turn sharpening on auto and see lots of artifacts
@richard.rothman Thanks for reaching out.
I’d like to help troubleshoot this for you. For this issue in particular, it would be easier if you submitted a support ticket using the beacon at the bottom of support.topazlabs.com.
I’ll need to collect further information about the computer, the app, and your image. I’d be happy to help you via email once you submit the ticket!
Hi Tim,
I tried your suggestion and bypassed Camera Raw, went into PS and then the Topaz AI filter. Same issues as before.
I tried the link you provided below to start a support ticket, but I don’t see, or even know what ‘ beacon’ you’re referring to. Please advise. Screen shot:
Happy to give you any other info you want. Just let me know.
Thank you,
Richard
RICHARDROTHMAN.COM
richardrothman.com
favicon.ico
](http://richardrothman.com/)
Try reloading that page. There should be a chat bubble that comes up when you first open it in the bottom right- that’s the support beacon I’m referring to. Thanks!
Hi Tim,
I’ve tried again, but it’s still not there. Can you let me know when someone has looked into the issue so I can try again?
Thank you,
Richard
RICHARDROTHMAN.COM
richardrothman.com
favicon.ico
make sure popups are not blocked in your browser.
It should look like this …
Try use Chrome or Edge browser.
For Firefox, You have to Disable “Enhanced Tracking Protection”, otherwise the beacon will not be visible, because javascript is blocked.
Base on the color of the shield icon (left of the address bar) clearly show that you have turn on Enhanced Tracking Protection.
スクリーンショット (110)a
スクリーンショット (110)b
Thanks for the help @lhkjacky
@richard.rothman It looks like you’ve submitted a ticket with us. We’ll continue helping you troubleshoot via email. Thanks!
