Artifacts appear when Upscale is set to 1x
Steps to reproduce issue:
- Step 1: Open B/W photo in Topaz Photo AI 3
- Step 2: Apply Denoise+Face Recovery+Adjust lighting
NOTE: I was testing different upscales. Finally, I decided to leave it the same size, so I left upscale in 1x. - Step 3: The result shows artifacts on all faces.
- Step4: If I remove “Upscale” from the workflow, it works as expected.
See attached example,
before and after processing sample.
Alex.-
Topaz Photo AI 3 on Mac
