Hi ! I would like to know for Iris if it is better with an Upscale x2 or if x1 is better for SD sequences. Even if the performance of the new iris is improved, in x2 or even in 1280x720, it lags quite a bit with my gtx 1660 so I can’t do too many tests… I’m currently trying artemis medium with the original recovery details at 100 % + iris, it gives me very good results by pushing the details of the sd sequence with “keepgrain =8” with qtgmc in Hybrid before. The details are well restored but the problem is that artemis medium adds but also removes quite a bit, visible in black colors. If I use artemis hight instead, it brings out too many artifacts. I tried nyx + iris but it’s not better. All this in SD. But could there be a step where I can render in 1280x720 with Hybrid using lancsoz or bicubis or bilinear etc or could an artemis medium x1 and iris x2 pass be better? In any case, iris v2 is better than v1, but on passages with fast movements, or the colors are dark, sometimes details are missing.
