Steps to reproduce issue:
- Step 1 load an image
- Step 2 go to enhancements
- Step 3 select adjust lighting
Topaz Photo AI [v1.2.4] on [Mac]
I will do as you suggest but it was brand new MacBook Air purchased 2 days previously and a new install from topaz.
I will go through your steps tomorrow
Robert Lakeland
Personal mail
Hello John S,
It is a MacBook Air less than a week old. I have followed your instructions and they made no difference. The only install other than migration assistant is Topaz Photo AI. I already had Topaz Faces AI which was installed by the migration assistant. I know about security settings and Photo AI runs perfectly except for this “Lighting Adjustment”. I have made a screen recording of an old photo that loads into Photo AI. I then go to add enhancements and 2 secs after I select it the programme crashes (quits). You suggested I reply to your email but it is a noreply email. How do I send you the screen recording?
See earlier comments. Here is a link to the screen recording
Hello John S,
Screen Recording 2024-03-18 at 5.56.32 PM.mov
drive.google.com
](Screen Recording 2024-03-18 at 5.56.32 PM.mov - Google Drive)
2.4.1 crashes as soon as I hit the Adjust lighting button.
New Mackbookpro, new Topaz AI
… any thoughts?
Same happens here on version 2.4.0 (not updated yet). MacOs M3 iMac
Ive uploaded the logs for today, there is no CrashReporter log generated
2024-03-21-14-03-44.tzlog (23.8 KB)
2024-03-21-14-02-52.tzlog (109.5 KB)
lastSessionFiles.txt (49 Bytes)
Adjust lighting in 2.4.1 crashes Photo AI just like 2.4.0. My last communication with Topaz support indicates that they are working on a fix. Perhaps with 2.4.2. I also found that while 2.3.x does not crash, Adjust Lighting generates an error message when using an M3 Mac.
Every time I try to use adjust lighting Topaz Photo crashes to the desktop.
Topaz Photo AI [v2.4.1 on M3 Max MacBook Pro
Updating to Mac OS 14.4.1 does not solve this problem with the M3 MacBook Pros.
Still a problem with Topaz Photo AI 2.4.2.
MacOS 14.4.1, Photo AI 2.4.2 & M3 processor: Adjust Lighting still causes app to crash.
Enhancement “Adjust Lighting” crashes all time when using it with a jpg.
Topaz Photo AI [v2.4.2] on Macbook Air M3
Having the exact same issue. This happens using Topaz directly, or using from within Photoshop.
App crashes on Adjust Lighting enhancement
Topaz Photo AI v2.4.2 on Mac
I have the same problem.
For version 2.4.2, the plugin crashes every time I add lighting effects to the noise reduction and/or sharpening processes.
I’d like to get some more information to help troubleshoot the problem you are having.
Could you send us your computer’s full system profile?
Also if you can, please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder.
You can securely submit your files(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Hello,
Thanks for the quick response.
Here is my system profile…
Model Name: MacBook Pro
Model Identifier: Mac15,9
Model Number: Z1CM000MCLL/A
Chip: Apple M3 Max
Total Number of Cores: 16 (12 performance and 4 efficiency)
Memory: 64 GB
System Firmware Version: 10151.101.3
OS Loader Version: 10151.101.3
Serial Number (system): M7K0GPMKMT
Hardware UUID: CDA497C5-06B0-55A6-90B2-1D883AA322EB
Provisioning UDID: 00006031-000C60EA01B8001C
Activation Lock Status: Enabled
Here is the log file from the most recent crash…
Filter Plugin Log.txt (9 KB)
