Add Noise slider does absolutely nothing (6.2.0)
I’ve tested on a variety of models, video sources and parameters using the comparison feature. All values for Add Noise from 0 through 10 render the exact same result, even when zoomed in to 400%. There’s no difference whatsoever.
TVAI v6.2.0 (I usually use the Add Noise feature and it seems like it used to function as intended, but noticed with this current version that it isn’t doing anything. Not sure exactly how many versions back this started though.)
Hi, adding noise is added before scaling and enhancing. If I do it, for example, on my SD footage, if I push the slider, it removes a lot of detail and blurs the video
Yes I used to use it for minimizing the noise reduction setting, but the feature no longer works in 6.2 for me.
Can you pull the logs and send any screenshots to the support team so we can look into this?
help@topazlabs.com
sent, thanks
